2016 Type-R Heated Seat Function Help
Hi everyone,
this is my first post and I am new to the F-Type R world so forgive me if this is. Silly question . In am about to purchase a 2016 F-Type R AWD from a local high end car dealer here In Ontario Canada, and noticed that the temp control knobs did not show the heated seat option and I could not find the function, the car was not running, just in accessory.
the car does have the heated steering wheel and front/ rear defrost options.
Does the car have to be running to see the seat image on the control knobs and to activate the heated seats.
thanks for any help
thanks for any help
On my 2014, I don’t recall a seat graphic. Push the knob in, the rotate it right to show 1-3 small red bars (1 bar is hot enough for me.). Rotate left to turn off (after pushing it.)
Car is in storage so I can’t check if it works in accessory, might not as it draws a fair amount of current.
If the ignition is not on the display will be blank. If the ignition is on but the climate control is off, you'll see a little seat icon on the top of the display and three red bars will light up as you turn the knob to switch on the heated seats. If the climate control is on, the display will show the seat icon below the temperature, along with "PUSH"
Also, I'm not certain about Canada but in the US, heated seats were standard on the R in 2016.
