2017 F Type
2017 F Type
Hi all,
I like to wash my own car but when I’m too busy, I run it through an automated car wash at gas station. I have a convertible and wondering if that is not a good idea. A lot of water accumulated on the wells of the trunk and some water leaked in while I was in the car wash. Does anyone else know if these car washes are just too strong for a soft top or is there an issue with my car?
It's not a good idea for a lot of reasons, but the leaks depend on where they came from. The window seals are like 3 or 4 pieces because of where it folds. The drivers side on mine will occasionally let a couple drips through when normally washing it with the hose if I put the jet nozzle near them. I took it through a touchless wash once in a pinch, and had some decent dripping on the drivers side whenever the jets came by the window, passenger side was fine. The seals don't quite overlap as well on my drivers side, so it makes sense, and they'd never leak during normal rain driving. But if yours is leaking from anywhere else, that'd probably be a concern.
I've been using automated drive through car washes for my past & current 5 convertibles over the past 25 yrs with no issues. 4 are ragtops: Mustang, 2 Vettes, & current F-Type, & 1 hardtop BMW. I've treat top with 303 once or twice a year. All are/were less than 5 yrs old & under 30K miles, all with no leaks nor fading issues, but don't have longer term experience. No paint issues neither, as all are properly waxed, & now ceramic wax.
No, I use 303’s kit. I use a horsehair brush with the cleaner, then I use a paintbrush to apply the waterproofing (I don’t mask anything.)
https://www.amazon.com/303-30520-Con...dp/B000A8JNF0/
The challenge with a brush - yes, it can go on thick, but doing it on a warm day in the sun, it absorbs quickly enough that it can be hard to tell what you’ve done. I open the roof, then mostly close it to leave a small gap above the windshield, so that I can coat the leading edge of the roof without any masking.
Yes, pour some into a small container, and work from there. After it’s done, the roof beads water like crazy - I use a cordless leaf blower to blow the water off the roof after washing.
Mbourne (05-06-2021)
