2017 F-Type R Tuned +100 HP
Old 03-20-2017, 08:08 PM
JVIII's Avatar
Originally Posted by Cambo
So there's no before-tune dyno number to compare with?
Currently flashing to stock. So we can compare..stay tuned.
  #42
Old 03-20-2017, 08:15 PM
Received 4,454 Likes on 2,426 Posts
Great!
  #43
Old 03-20-2017, 08:25 PM
JVIII's Avatar
Originally Posted by Shikatsu
I'm really curious about the results since I'm also from Irvine. I may have some questions for you after you post the results. =)
For sure my man. I'll post the results once we're done with the dyno test.
davetibbs (11-08-2017)
  #44
Old 03-20-2017, 08:39 PM
JVIII's Avatar
Still running..
  #45
Old 03-20-2017, 09:19 PM
Stohlen's Avatar
I assume since you were on the hoist they had to pull the front driveshaft? Not a linked dyno. Interested to see how that effects things.
  #46
Old 03-20-2017, 10:29 PM
Mpowerr's Avatar
****, that hopefully was an alignment and not pulling the front driveshaft. We shall see, I'm kinda with you on this one...
  #47
Old 03-20-2017, 11:02 PM
JVIII's Avatar
Hey guys,
Just a quick post, after doing 7 pulls we're having unhealthy reading on STOCK tune. GSR's team figured that we need to change the spark plugs because it happened to one of the F Type R as well and they fixed it by changing it.
By the way my car is brand new..so probably we have bad spark plugs from the factory?
Reading was based on power dipping at 6000 rpm and suddenly pulling back up. I'll post again once we fix this problem. I'm already getting a quote to get the spark plugs replace. Hopefully they can do it this week.
Thank you all!
  #48
Old 03-20-2017, 11:36 PM
Prophizee's Avatar
Originally Posted by JVIII
Hey guys,
Thank you all!
oh no brother...Just make sure its spark plugs and nothing more. Can't wait to see these numbers. I'm ready to eat some humble pie from my earlier comments
  #49
Old 03-20-2017, 11:46 PM
WhiteTardis's Avatar
Ahh you're at Lang Racing in Irvine/Lake Forest. My office is a couple of miles away. Woul have loved to see this in action. Lang runs a well put together shop
  #50
Old 03-20-2017, 11:51 PM
JVIII's Avatar
Yes, we did it at Lang. They're the ones who's going to replace the spark plug or Boden Autohaus.
I'll let you know when's the next dyno
  #51
Old 03-20-2017, 11:52 PM
JVIII's Avatar
Can't wait to see the final output too! Of course, once we fixed this problem.
  #52
Old 03-21-2017, 01:00 AM
Unhingd's Avatar
Received 4,661 Likes on 3,366 Posts
Bad plugs should be under warranty. They're designed these days to last 100k on modern cars.
jaguny (03-21-2017)
  #53
Old 03-21-2017, 09:06 AM
JVIII's Avatar
Not unless you can find me a way on how to ask them without them doubting why I specifically asked for a spark plug replacement?
  #54
Old 03-21-2017, 10:28 AM
Originally Posted by abstruse1
I looked at the Velocity Website and, as I understand their graphs for their reflash kit, you give up a LOT of lower RPM power (hence torque) to get their advertised max HP gain. Sounds like a bad deal to me, unless the car is a track car (maybe even a bad deal t hen).
Am I missing something?
I think you're missing something. You don't lose any lower RPM torque or HP to achieve any of our gains. I'm not even sure what a tuner would be able to do in order to 'lose' low end HP/Torque. It's not exactly a packet of cigarettes, not going to fall down the back of the couch!
The only way you would lose low end torque or HP on these cars is if you went in and de-tuned the car in that RPM range.
__________________
Stuart Dickinson
Managing Director
VelocityAP Industries Ltd.
O: (1)250-485-5126
E: Stuart@VelocityAP.com
www.velocityap.com
  #55
Old 03-21-2017, 10:36 AM
Hey guys,
Thank you all!
It's not your plugs. If you did 7 pulls on the dyno then you are most likely hitting catalyst over-temp protection mode and the car is either dumping fuel, or pulling timing to get the EGT's down.
These cars are extremely sensitive to cat temps, even 2 pulls in consecutive order without adequate time in between will tip them into protection mode. You need a lot of airflow (I don't see a big fan there, but I'm sure you have something set up there?) and if you can get a couple of fans pointed at the cats as well that will help.
Interestingly, having seen a few 'VMax' tunes from people who switched over to our stuff, one of the most concerning things was the fact that some of the protection mode maps had been edited to lean out the AFR. My guess is that the tuner was running the car on the dyno and seeing rich mixtures and editing the tables thinking they were the optimum fuel strategy, when in fact the car was just too hot and they were editing the safe mode tables.
We are well into the 100's of tunes for these and the V6 engines, multiple dyno sessions and I've yet to see a set of plugs go bad as a result. I would monitor your cat temps and allow more time between runs, before you go changing them.
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
The following 2 users liked this post by Stuart@VelocityAP:
DJS (03-21-2017), Mpowerr (03-21-2017)
  #56
Old 03-21-2017, 10:37 AM
Also, to the OP - see you joined recently. Welcome to the forum, it's a really good crew here, and your car looks fantastic. Congrats!
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
  #57
Old 03-21-2017, 11:12 AM
KSFTypeR's Avatar
"if you can get a couple of fans pointed at the cats as well that will help."
Stuart,
Isn't the cat temperature calculated rather than measured? I am less familiar with Ford/Jag, but that is typical from what I have seen.
  #58
Old 03-21-2017, 11:18 AM
CRS 123's Avatar
Just curious....a brand new car with no run in period...multiple engine stressing dyno runs. I"m no expert, but this does not sound like a healthy thing for the engine.
CRS
ralphwg (07-02-2017)
  #59
Old 03-21-2017, 11:36 AM
Prophizee's Avatar
CRS
I think the whole thing is a little weird but OP seems very determines so hats off to him.
  #60
Old 03-21-2017, 11:53 AM
JVIII's Avatar
CRS
I daily drive the car so I already have 1700 miles..don't know what are you pertaining about the "run in period"?
