2017 F-Type (x152) AC not blowing cold air
Took my recently purchased 2017 F-Type (SAJWA6AT0H8K35631) to my mechanic who said it needed an AC recharge. AC was working but not blowing cold air. After recharging and adding a dye, it still was not getting cold. He said it didn't look like the fan was working but didn't have time to check it out. Did a scan and found several issues listed below. Does anyone have any suggestions on how to diagnose the AC issue and/or know of a service bulletin on diagnosing AC issues? I did check the fuses.
Scan codes
- P1308-13 Intermittent - A/C Clutch Circuit
- B13C2-49 Intermittent - Windshield Misting Sensor
- U2002-92 - Permanent - Switch General Electrical Fault
Any help would be greatly appreciated,
Thanks,
Mike
Scan codes
Thanks,
Mike
I had a similar issue last summer. I don't remember codes showing up for me, only that the AC air would always blow warm. I think this happened after I did a semi-hard pull with the AC on...
Turned out I needed a new AC compressor because the clutch wasn't activating.
Was about a 1.5k job at a Euro mechanic with labor and parts.
Sucks, but I hope this helps!
