2017 MY R Exhaust Valve Redesign?
#41
#42
Hello,
My Car is a brand new 2018 model F-type S that I drive for a moth now and I share a similar experience. The car is equipped with an active exhaust but has no exhaust button.
Compared it yesterday with a 2017 S mod and what a difference.
In my case the issue is definitely software related.
The valves are open at startup and close after 3 seconds. By acceleration I need to go over 4000rpm range in order to open the valves.
The dynamic or track button make no change in the situation.
I also pulled the Fuse 15 in the engine bay in order to disable the vacuum pump.
This made a difference but the 2018 still not leveling with the 2017 S or my previous 2014 F-type with 340hp and active exhaust button.
For me, other than the software Jaguar re-designed the mid or end damper in order to lower the sound level of their 2018 cars.
Anyone has this info ?
I will contact the dealer in order to have the button mounted if possible and hope that this will make a change.
Reactions are welcome,
Ray
Ray
#43
Hello,
Ray
Ray
#45
#46
Hello,
Ray
Ray
also when I put my car in dynamic the valves open (on) I know this as the LED is on in the active exhaust switch. Also note I have completed just over 1200 miles now and the exhaust has got louder, this can happen when the baffle material beds in
regards
#48
#49
If someone is telling you they updated the software to keep valves partially closed so the car would pass CARB emissions? If so that sounds like the biggest Porky Pie I have heard in a long time. Exhaust valves don't have a single thing to do with emissions.
__________________
Stuart Dickinson
Managing Director
VelocityAP Industries Ltd.
O: (1)250-485-5126
E: Stuart@VelocityAP.com
www.velocityap.com
![](https://www.jaguarforums.com/forum/signaturepics/sigpic147732_1.gif)
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
#50
#51
Gotcha, that makes much more sense. The O2 sensor update would be emissions related, if they bundled it in with some exhaust valve mapping that would explain.
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
#52
I had the k309 done in Mai 2016, and did suspect that it had reduced the pops and crackles a bit. However this was just after I had taken the car out of Winter hibernation, so my "referanse" was a bit rusty.
Yesterday I had the car in for service and told them to check for a TSB495 action. They also cleaned and applied some copper grease on the hinges on the exaust valves to prevent them from getting stuck partly way open. This was done just as a preventive maintanance, as the valves did function well. However the passenger side valve opened just close to 100%, but nitpicking one could say it did not open fully. That would not be enough to cause any change in sound levels though.
They did the TSB495 update, and there is no doubt that it had an effect on the pops and crackles. They are now back to full, and after driving the car during the whole summer without it, it is VERY easy to notice the difference now. And it's all because of the software.
