2017 V6s tune/pulley/trans tune questions
I'm interested in doing the stage 3 mods to my V6 S, w/trans tune, and have a few questions that I'm sure the folks here know the answers to.
1) Can I purchase the lower+upper pulley and tune file/tuning device, and just install the lower (or no pulley) for right now with the Stage 3 tune? Will I get 416HP with no pulley installed?
2) Do I need a different supercharger belt for any of the combos of pulleys?
3) Is there an engine "tuning device" that can also reflash the transmission? Or must I purchase 2 different devices?
I'd like to take advantage of the current sale, but won't have time to do any significant work on the car for a bit.
Received 3,208 Likes
2) If you install the larger crank pulley then you will need a longer SC belt (which VAP supply as part of the pulley plus Stage 2 or Stage 3 package anyway), but for the tune only or upper pulley only you do not need to change the SC belt.
3) To tune/reflash the trans you would need to purchase the separate TCM tuning device from VAP.
If you buy the complete package - both pulleys, all tunes and both tuning devices - then VAP just might be kind enough to offer a reduced price package deal but that is up to them.
GeorgeIII (11-23-2022)
As much as I'd like to do this all at once, I need time to pull the supercharger and replace the coolant pipes, change the coupler, oil and the upper pulley at the same time.
I ordered the Stage 3 setup with trans tune. Are there custom options, like removal of torque limiting, reduced/increased pops n bangs and a reduction in that high RPM startup protocol? I don't like that the engine revs way up upon cold start.
I am still thinking of asking for the initial tune for "no pulleys", and then change over when I find time to install the pulleys.
A lot of people jump right to cutting the SC pulley because they don't know how to do it properly. It's a cinch to remove....don't cut it. The proper pulley tool (the one USP sells for the mini Cooper works great) and a heavy duty cordless impact will zip it right off. I used a Rigid hd with 1200+ ft lbs and the pulley was off in 10 seconds. The hammering is what does the trick. Trying to do it with a basic puller and a socket wrench will just leave you with a bent up pulley and a foul mood.
cujet (11-30-2022)
Sorry, brainfart. I deal with USP at work. Uro tuning is what I meant. Here's the link
https://www.urotuning.com/products/alta-supercharger-pulley-removal-tool-r52-r53-mini-ampeng208
You will also need a steering wheel puller like this guy:
https://www.amazon.com/dp/B0868DB783?pd_rd_i=B0868DB783&pf_rd_p=4e1ed69f-9511-4631-b8a0-4f05f5875119&pf_rd_r=Y7GCDVBAMNJ46TGWTVGZ&pd_rd_wg =7MTiP&pd_rd_w=SirHu&pd_rd_r=65c555cc-4405-486a-9cbc-0f713093ad59
Fyi, I didn't even attempt the job without pulling the hood. I'm old and big and couldn't get in there at all. Maybe a small young guy could do it without (VAP says you can) but not me.
I don't know which tool USP was selling but a simple search on eBay Motors under "Mini Cooper supercharger pulley removal tool" gives heap of hits for the same Alta 2 piece tool, see here: https://www.ebay.com/sch/i.html?_fro...ol&_sacat=6000
It's a two part collar which bolts around the pulley but it's not clear exactly how you then pull the pulley off, although there are four threaded holes in the collar and some of the ads say "Steering wheel puller is required for stock supercharger pulley removal" so that's a couple of clues!
Edit - too slow as usual, beaten to the punch by Doc, but it looks like the exact same tool anyway.
cujet (12-09-2022)
Get E85 tuned for 553Hp if you already have both pulleys replaced, I did and it is as advertised. With this tune you will be only 22Hp short of the F-Type SVR, for a lot less dough. VAP Tune: https://www.velocityap.com/product/a...5-tuning-file/ And go here to find the Ethanol pump nearest you: https://afdc.energy.gov/fuels/ethano...arest?fuel=E85 Have fun! I hit 170 in my XE yesterday, and had power for more but I had to slow down before I topped a hill. A few years ago I'd taken my Ninja 1400 past 190 before, but not a car. It seemed pretty settled (I added a spoiler) but the road was too bumpy, so I slowed down. I need to take it to the Salt Flats (but they were flooded this year). The XE Project 8 hits over 200Mph with 592HP. My car has only 29HP less than the P8. Maybe 190 next year on a closed course? Pretty fast for a sedan!
Mine's a convertible, and I do use what it's got, but I'm not racing anybody anymore, just looking for a satisfying amount of thrust. I use E85 occasionally in my tuned 2009 F150. It adds a bit of power and with E85, will smoke the tires at will (In 2wd) . The Racetrac station nearby sells it. (low end gas station)
In years past (early 80's) I worked as a factory tech for racing outboards for lake boats. I also worked as a engineer/tech for a company developing a camshaft for a turbocharged 4 cyl engine, doing many dyno runs to assess HP and emissions compliance. Also involved in turbocharged engine development, with 700HP 1.7 and 1.8L road racing engines, along with vintage race car stuff, and in between my current Aviation career, some Porsche stuff back in the 90's. I also get to drive some of the worlds fastest cars, as my current employer is a "hypercar" guy. He and I raced an Enzo and McLaren F1 some years back. The F1 would pull 700 feet on the Enzo, then they were even. Oh the joys of "nanny" features on the Enzo. Here I am in the Enzo following the F1.
![](https://cimg2.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/640x480/xsxkg5ul_713bdd6827f84b3c37687618630af5d2c93b44aa.jpg)
Yeah, the E85 will make you a thirsty beast, but it's worth it. I strongly recommend if you go E85 that you keep a can or two of Boostane on hand. Last week I filled a third time at my local station, and by the time I got it the mile home it started sputtering and loping at idle. Turns out I had bad E85 on this fill, I added boostane to the fuel and it got back to running normal.
I drove until I drained the tank and filled up at another location, she purrs like a kitten again at idle, and runs great! Going out for a drive today, I'll plan the route around E85 availability today.
It's gonna be 82 Degrees today in Austin, on 12/9 ! I'd prefer cold for boost reasons...lol.
For those running e85, make sure you buy a test kit and check the actual ethanol levels at your pumps. I have seen a lot of them that have stickers saying it may be as low as e70 which is a no go. Luckily the only station around me that has it tests out around 82% so no issues. It's like $12 for a test kit but might be the best $12 you ever spent.
I can't just pour it in the garbage for a number of good reasons, lol.
Good idea, first thing I ordered after I had a problem. Do you just fill a little in a tiny empty gas can, or use some other container to collect a sample? Can't pump right into the kit...And how do you properly dispose of the sample at the gas station?
I have a stage 3 tune from VAP that was a little too hot for 93 so most of the time I just run that tune on an e25 blend . Works great.
dennis black
08-20-2022 02:19 PM
