2019 F-Type Has Summer Tires, Want All-Season Tires
Good Afternoon,
I don’t remember any car dealer asking what type of tires we wanted. We have always had all-season tires which have worked fine during winters in western New York, USA. Our 2019 4-cylinder Jaguar F-Type arrived with Continental SportContact 2 tires which are summer tires. They will not be a good choice for the winter months.The F-Type is my daily driver, all year long. I may drive it 2000 to 3000 miles per year.
I looked at some other "tire threads". Let me know if there are any other options that I did not think of and I will then pick one.
Option #1: Do nothing. Drive carefully through the winter.
The streets are not covered with snow every day during the winter. When there is snow, the streets are plowed early or within 24 hours. If there is more than an inch of snow on unplowed streets, I will stay home![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
Cost: $0.00
Option #2: Buy snow tires, unmounting/mounting tires when the seasons change.
I suppose that this can be rough on a tire’s bead, the part of the tire touching the wheel. We will need to drive a second car carrying the 4 tires to the tire dealer at the change of the season to have the tires unmounted/mounted, beating up the beads.
Cost: a set of snow tires + yearly cost of unmounting/mounting
Option #3: Buy snow tires and a set of wheels.
This eliminates the wear and tear on the tire bead. We will need to drive a second car carrying the 4 tires/wheels to the tire dealer at the change of the season to switch tires. I could do this if I feel energetic and buy a jack and a torque wrench.
Cost: a set of snow tires and wheels + yearly cost of uninstalling/installing wheels/tires or the cost of a low profile jack and torque wrench.
Option #4: Discard summer tires and buy all-season tires.
Discard the new set of summer tires, now, and buy a set of all season tires. Car life is now what we are used to.
Cost: set of all season tires
Option #5: Combination of option #1 and #4
Start with option #1 and drive on the summer tires as long as I can. If it is a mild winter, I won’t need the all-season tires. If I reach my “threshold of pain”, then switch to option #4 and buy a set of all season tires.
Cost: eventually a set of all-season tires.
Thanks for your ideas,
Bill
Cost: $0.00
Bill
jetsetter883 (06-26-2022)
Uncle Fishbits (02-28-2019)
I live in CT and try to drive my car as much as possible through winter (RWD V8S). I absolutely would not go out with any snow on the ground though, even less than 1 inch. Once the snow and salt starts I switch over to the SUV.
If the F Type were my only car I would get a dedicated set of rims / winter tires and switch over once it gets cold enough.
Seriously, in your locale, I'd either go ahead and buy the All-Season now, so you can (hopefully) sell the Summer tires as essentially new. They won't have a lot of market, but you could some off-set some of the cost. If they don't sell at all, you can still swap them on your current rims next year.
Be careful if the wife advocates Option 1; it would be a reasonably effective way to cash in on the life insurance.
Hey Bill, the issue is not the snow. The issue is that when it is cold, your summer performance tires will turn into hard blocks with no grip whatsoever and slide on anything. I live around NYC and discovered this at my expense during my first winter with such tires (I thought, why spend the money, I'll drive slowly on snow). After leaving my car parked for a few hours in a lot on a day when it was cold, I started to drive it in reverse very slowly... lo and behold, the car started to slide across the parking lot (which had a slight incline) and I ended up with my car on a sidewalk all the way across the lot. I was fortunate not to hurt anyone or anything along the way. There was not much snow, and I must not have reversed at more than 5mph... but my tires had turned into skis in the cold and would not grip at all. You would do better with traditional tires but the summer performance (which I suspect you have) are truly dangerous in cold weather, snow or no snow.
Bill. (07-06-2018)
Western, NY = Buffalo, or someplace just like it. Best solution is park the F type in a garage with a Battery Tender on it and lease or buy a cheap Jeep or similar. That weather in WNY is unpredictable as h*ll, sun out in the morning, 10” on the ground in the afternoon. Let it be a 2-3 season car and enjoy it!
I live in CT too. I never drive my high performance cars in the winter anymore (I drive one of my SUVs instead) because they are usually not that great in the snow even with proper snow tires and most importantly to avoid road sand pitting of the paint - although not as much sand is used anymore. A new hazard is the new salt formulation they use instead of sand or salt/sand that eats cars here - its amazing how corrosive the stuff is. Before I started doing this I always used an extra set of wheels with snow tires (usually Bridgestone Blizzaks). I originally used studded snow tires but they are not a good choice on a high performance car as they can be a hazard themselves due to the studs if you forget about them and drive too aggressively.
Good set of options. If I were in your shoes...
Option A: All seasons now, sell "as new" summers
Option B: Summers on original wheels for "driving season", winter tires on less expensive but still attractive wheels for the salty road season.
Option C: If within budget considerations, buy or lease a small SUV. Great utility all year and in winter have fun plowing through the snow and doing some Ken Block style sliding around.
Summer performance tires become Flintstone's rock tires when it is cold. Below about 50 degrees F performance starts to fail. As it gets colder the structural integrity of the tire will suffer over a fairly short time creating a dangerous situation. Like dry rot, the tire might look fine, however...
Hi Hayabusa and Brock,
In parallel with you writing your replies, I sent an email to Continental and they said the same thing including that their summer tires are prone to cracking below 45 degrees. That eliminates my Option #5.
We are leaning towards your Option A, buy all seasons now, sell "as new" summers ... to another F-Type owner with 18" wheels ?
Thanks,
Bill
Thanks,
Bill
absolutely DO NOT do Option #1. the people telling you this are all people that have lived to tell the tale...its not a fun experience.
the most logical option is to just buy winter tires and swap out seasonally, but it can get annoying.
I've gone the all-season tire route....so far no severe issues. just be extra careful and you'll be fine
You didn't say what diameter wheels you have. If your F-type came with the standard 18" wheels, there is no snow tire fitment available for the original wheels. I've looked. Also I haven't found any "approved" recommendation for an after market 18" wheel + snow tire set. There are original wheel snow tire options for the 19"s though.
If you're on 18"s I have the same tires as you. For now, when there is snow and salt I drive my Saab but otherwise I do drive the F-type in winter. Eventually I'll replace the original tires with all seasons, probably Continental Extreme Contact DWS06.
-Jim
-Jim
Jim,
Sorry for the tire size omission.
Front:
If I wanted tires and wheels I guess I would have to get narrower a narrower wheel, one the same size as the front.
My plan dejour is what you specified: Continental Extreme Contact DWS06
Thanks for the clarification.
Bill
Front:
tire: 245/45 r18
wheel: 8.5J x 18
Rear:
tire: 275/40 r18
wheel: 9.5J x 18
I double checked TireRack.com. They have winter tires for the front but not the rear.wheel: 8.5J x 18
Rear:
tire: 275/40 r18
wheel: 9.5J x 18
Bill
So many different opinions, suspect it comes down to personal preference.
Some countries in EU mandate snow tyres be fitted in October onwards I believe.
I live in UK, it's a choice left to owner's discretion. Where I live we can get snow especially on higher ground but at lower levels it doesn't occur every year.
My personal choice has been option one but I accept this may not be right for your circumstances. I haven't been out in my RWD type R in snow as it didn't snow last winter, although I am aware summer compound tyres aren't ideal especially below 7°C I found the grip to be adequate if caution is exercised even on less than ideal P Zeros. The rain / snow setting on ESP / traction control will also help.
A previous car I owned was a GT-R with 580bhp albeit via AWD, I drove all year round including snow on summer tyres without problems.
I covered 45000 in three years, never slid off the road. I got stuck in snow on two occasions and dug myself out with help, I don't believe snow tyres would have prevented me getting stuck as on both occasions it was due to lack of ground clearance rather than lack of traction.
