2019!Ftype tire pressure fault not reading any pressure
I read all the tire pressure issues on the forum yet mine is showing the tire fault message and none of my wheels are showing any readings like it had before. I used to see each tire pressure individually and now it’s just a line on each tire where number would tire reading would appear. I have lowered all the tires with car off and then started the car and put air in each tire to 37 as indicated. Then driven over 100 miles at about 70mph and still no reading . The last time I took car in for service I was told that they changed my battery and the module of tire sensors and when I left it all worked perfectly for a week or so. I have looked for the antennas and they are all in the brackets they need to be. The tires all have the metal tips and metal caps as indicated. Where is the module located? That’s the last thing I have not checked because I have no clue where the module is located and by deduction it might have a lose wire or something . The update on the tire module was updated last time also. Only other thing is that I have a CarPlay from unique auto and my car is the latest system not the Bose or Harman but the Harman tcpip system and CarPlay works more or less well with the unique auto device.
1:where is the tire pressure module located ?
2: can there be an issue with the unique auto device interfering with signal or tire monitoring ?
The dealer is about 50 miles away and one has to schedule an appt. The appts are about 60 days out. So if I can’t figure out the situation by the next 50 days then I have a standing appt. Yet it’s very annoying to see that yellow light and have that tire fault everytime I’m driving as I’m sure it would be for most .
Ntimd8
08-12-2019 05:32 AM
