2020 VS 2021 F-Type Exterior Interior Comparison
#41
#42
This is from the XE manual:"The layout is configurable for the interactive driver display in the virtual instrument panel. Select the Display and Display layout instrument panel menus to view and select the required option. The currently selected display layout option is retained after the ignition is switched off and back on again. Select the required display layout option to suit driver preferences.
The available display layout options are as follows:
- Two dial: Select this menu option to display both the speedometer and tachometer dials, as illustrated. One information panel is displayed between the dials.
- One dial: Select this menu option to display only the tachometer dial. Two information panels are also displayed, i.e., one to the left and one to the right of the tachometer dial.
- *Full map: Select this menu option to display an expanded view of the current navigation system information.
- *Media: Select this menu option to display an expanded view of the current media source information.
- *Driver assistance: Select this menu option to display an expanded view for the currently enabled driver assistance features.
This is the standard setting usually with some information between https://www.caricos.com/cars/j/jagua...images/54.html
