2021 F Type R Downshift issue
Just picked up a 2021 F type R 3 days ago and the car when downshifting from 5th to 4th using the paddle shifters does not smoothly engage. There is a bang/clunk which is very noticeably felt in the transmission while going into 4th gear. Every other gear downshift is very smooth as it should be. This happens in both regular mode and dynamic. When applying throttle and doing the downshift it is significantly better. My concern is every gear change besides the 5th to 4th is smooth regardless of throttle input. It just doesn't feel right. The thought of having to bring the car in for a transmission issue 3 days after purchasing is extremely worrying.
Received 3,209 Likes
Can this possibly be part of the "learning phase" of the transmission? it is a lot smoother when applying throttle and then downshifting into 4th. Dealership is about an hour commute each way so I'm curious if its something that will correct itself as the transmission "learns". The car only has a little under 200 miles.
