2021 Front License Plate Bracket
I just drove home my new 2021 BRG R with Tan interior, here is the link... https://www.jaguarreno.com/inventory...d51fe1mck71084 This is my 3rd F Type which should put me in their "fiercely loyal" category. I have programmed the garage door, community gate and lastly tried to remove the front license plate. However, they installed two receiving brackets that are bolted from behind. Before I "hire" someone to remove them, has anyone out there successfully accomplished this?
Thanks in advance...
Dave
Dave
Carbuff2 (06-02-2020)
As you can imagine, the pricing on the 2020's is very good and for the few remaining 2019's it's great. There was only one 2021 at the Sacramento California dealer and one at the Reno store. Sacramento offered me $500 off on the V 6 because I'm a "valued customer". That offer was kind of an insult as I would have been more comfortable with, "it's our only one..." I went to the Reno Store to actually buy out my lease on my 2017 R. However, the only one they had was on the showroom floor and you know how that goes. They took $4K off and said, "we've priced this to sell if you're interested" I replied with, let's do this!
Now you have me wondering if I truly am that creature of habit!? My first F Type was a MY 15 S IRR. Boy, did I love that car, as it truly was a new experience. That car was on the showroom floor and I'm a sucker for that set-up. The second was a step-up to a MY 17 R that was Ammonite Grey with Red Interior. You guessed it, showroom floor got me again. I really appreciated the difference in the exhaust notes however, there were no flies on the 2015 S exhaust notes. The current 2021 was, yes... on the showroom floor. I finally drove it today from our home near Lake Tahoe to our place in Granite Bay. Not a real great experience on a couple of levels. Specifically, the car is significantly more quiet and if you want a pop and crackle you really have to gear down and stomp on it. By the time I got home, it seemed to be a little more throaty. But, this could be a combination of wishful thinking and imagination. I will (have) to get use to this over time as there are 35.9 months left in this chapter. The handling of this car on Highway 50 which is full of twists and turns in simply amazing. The new suspension and wider tires are responsible for this however, the damn tires are so loud my ears were ringing when I got home. There are bad enough that I will be calling Jaguar to see if they have a suggested solution.
Received 3,209 Likes
If so you would think that JLR have learned by now that they are crap and gone to something else like MPS4S for OEM fitment.
I'm guessing they are contractually locked into the P-Zeros.
Burt Gummer (06-04-2020)
Thanks for the info. Sounds like a fair deal for a new model. I guess their showroom floor truck works every time!
Mine is a 17 in ammonite grey with red interior like your old one and that's a magic color combo too!
Look fwd to hearing if you manage to spice up the pops and crackles!
The pictures below is one of the two brackets that held the frame for the front plate. The top picture shows the bolt that needs to be backed-off to pull the bracket out. Unfortunately, this bolt is behind and therefore near impossible to access. However, please note "near impossible" should not stop you from attempting this. I was able to find a very thin and short 8mm wrench that slipped over the bolt. Then, you can move the bolt a bit at a time until it finally allows you to spin the hold down from vertical to horizontal. When in the horizontal position you can pull it out.
I'm late to this post, but I found an easier method - use needle nose pliers to break all the outer retaining points on the bracket, then unscrew the outer bracket until the rear retaining bolt loosens. Then use your needle nose pliers to turn the bolt by grabbing the threads. After a few turns, you should be able to maneuver the back "wing" of the bracket that is behind the grille face to a horizontal position and work it out through the grille. I couldn't figure out how to get a wrench behind the honeycomb without scratching it - as long as you intend to toss the brackets, this is a good 10 minute operation.
Portlander (12-03-2023)
Now that there has been success in removing the license plate bracket, has anyone actually installed one and would it be the same difficulty in reverse? I have a 2021 R and purchased the bracket back in April just in case I got pulled over multiple times in my state that requires front plates. My plan was to accept the warning for the first stop, pay the fine for the second encounter with law enforcement and actually have installed if there was a third. With limited tools I would need to have the dealership take care of it and so far so good and hopefully I can make it through another summer.
https://stonsho.com/collections/f-ty...ept-svr-sns139
There is already a bolt dead center under the front splitter, so you just take off the one bolt, put the bracket receiver under the splitter and then reinstall the bolt. Mount your plate to the frame and then keep it in your hatch (or install it on the front of the car if you really want to). Should you get stopped, you can just say you took it off for washing and forgot to put it back and you can offer to put it back while you're stopped on the side of the road. It takes less than 10 seconds to insert the plate/bracket into the receiver to give you a front plate again. It's an ingenious design, excellent quality, and--most importantly--preserves the nose of your F-Type from the hideous front plate. MA has a similar law and I've yet to have my Sto-N-Sho plate on the car and I've never been stopped for it. But if I am, I can fix it in seconds.
The following 2 users liked this post by Thunder Dump:
Portlander (12-03-2023),
Rob Schwartz (12-13-2023)
