2021 front license plate removal???
Old 02-12-2021, 08:16 PM
GeorgeIII's Avatar
Originally Posted by Llama
Don't bother. Get a Sto N Sho (https://www.jaguarforums.com/forum/f...racket-144955/) like many of us have. It's removable, doesn't require drilling holes and you can take it on and off in seconds. Mine lives in my trunk. Should I ever get hassled about not having the plate on, I'll make sure they know I "forgot" to put it back on after washing my car and can have it mounted up again faster than they can write me a ticket. The install is dirt simple, too.
Absolutely agree. The Sto N Sho is great, super easy to install and it’s solid. It sits much lower than the factory plate and as Llama says, you can always try the I forgot line should you get stopped. Here’s what mine looks like.
Old 02-12-2021, 08:24 PM
bjg625's Avatar
Wasn't Tahoe Dave the first to deal with this?
Old 02-13-2021, 09:10 AM
myironlung's Avatar
Just wanted to update and say the dealer was able to successfully remove the front plate and brackets. Of course at first they told me it wasn’t possible but I told them I checked with some of you guys and kinda made it an issue with them. Within a day I get a call from them “oh hey so yeah we were able to remove it” haha yeah no **** 😂😂😂😂
Old 02-13-2021, 11:02 AM
Dwight Frye's Avatar
It's funny how with the invention of the internet and popularity of discussion forums like this one and about any other make and model of vehicle, that owners often know more or discover issues long before dealers are aware of them.
Old 02-13-2021, 12:08 PM
scm's Avatar
scm
scm is offline
Received 1,460 Likes on 1,105 Posts
But dealers still try to disparage we "armchair technicians" ....
walko789 (06-06-2022)
Old 02-25-2021, 07:33 PM
ultimix's Avatar
Sorry, I meant the plate holder. Reading the posts above, it looks like there are a pair of brackets attached to the grille and then a flat plastic plate holder screwed to the brackets that the actual steel license plate attaches to. From reading Tahoe Dave's and JonnyM's posts, the flat plastic plate comes off easily, but the two brackets need to have a bolt loosened from their rear to allow a clamping piece to rotate and clear the slots in the grille for removal.
Did you get the bracket off successfully?? Just took possession of my F-type tonight.
thanks
Mark
Old 02-25-2021, 10:38 PM
davidlg16's Avatar
you need a 8mm ratchet (not too big and as flat as possible so it fits inside the mesh) to unscrew the back screw enough to turn the vertical plastic piece horizontal before you can remove it
took me a good 20 minutes cuz the space is small to work with
  #28
Old 02-26-2021, 01:37 AM
spegor's Avatar
Just my two cents, there is a lot of air flow blocked by the plate in that low position, more than in the in the centre position because of the spoiler effect. You could also minimize the spoiler effect for stability pourpose
Old 02-26-2021, 02:32 AM
GeorgeIII's Avatar
Thank you for your advice. The bottom of the plate sits less than a 1/4 inch from the spoiler and about the same on the top by the chromed oval. Do you think this is going to adversely affect the aerodynamics at 80/90 mph?
In any case, more often than not, I do not run a front plate which is why I purchased the Sto&Sho. If I got stopped, I would have the plate and would plead stupidity that I forgot to put it on after getting the car washed.
  #30
Old 02-27-2021, 05:52 PM
Davidlg16, would one of these stubby ratcheting wrenches in 8mm work well for removing the bolts ?
  #31
Old 02-28-2021, 02:12 PM
davidlg16's Avatar
you can use thick ones, just take a little longer, the thinner one you can just twist 270deg where as really thick one you can turn maybe 90 deg and then reposition
  #32
Old 02-28-2021, 04:28 PM
Thanks I'll pick up a set of the ratcheting wrenches at Harbor Freight. They are only around $27 before any coupons and I'm sure I'll find other uses for them. One can never have enough tools right ?
  #33
Old 03-03-2021, 07:27 PM
ultimix's Avatar
Is there any racket that would work best. I purchased one the other day and I could not get it on the head of the bolt. I got frustrated pretty quick.
What is the best way to back out the screw so you can at least feel the head of the nut?
Any idea would be greatly appreciated!!
Mark
  #34
Old 03-03-2021, 07:35 PM
davidlg16's Avatar
Mark
I bought this and worked well
https://www.homedepot.com/p/TEKTON-8...8277/205763551
  #35
Old 03-04-2021, 09:41 AM
ultimix's Avatar
Originally Posted by davidlg16
Thanks!
Mark
  #36
Old 01-15-2022, 08:57 PM
Lhonniball's Avatar
Default Removed Front Plate Brackets
I just removed my front plate brackets on my 2021 Jaguar F-Type R. I read all the threads which was really helpful
Here is how I removed the brackets. I used Drexel tool and cut a slot on the bolts. Then I used a small flat head screwdriver and backed the bolt out until the piece holding the bracket was loose enough to go horizontal and fit through the grill and the bracket was out. Took about 15 minutes to remove both brackets.
Jag looks much better without the plate in the grill
  #37
Old 03-09-2022, 06:55 PM
Stark911's Avatar
Default Easy Removal
So I read all of your threads and were very helpful. That said, I knew I had to find an easier way just using some locking pliers and it took me no more than a minute to remove both. Here are some pics of the bracket removal of my 2022 Ftype P450.
Here is that bracket.
Using locking plier. Doesnt need to be extremely tight, just enough to turn it clockwise as much as you can pushing the bolt in.
After the bolt is almost flush, you can stick both your index fingers to loosing it even more until you will be able to turn the vertical plastic horizontal.
Here is that plastic piece that holds the bracket from coming out. It is shown horizontal now since i moved it
Finish product.
Carbuff2 (03-10-2022)
  #38
Old 03-10-2022, 10:45 AM
Carbuff2's Avatar
I never noticed that little "F-Type" Easter Egg in the facelift grilles. Thanks for sharing.
  #39
Old 03-10-2022, 10:37 PM
McPhaul's Avatar
I used a Dremel Rotary Tool. Works great and reversable.
https://www.jaguarforums.com/forum/f...emoval-252117/
  #40
Old 03-11-2022, 10:14 AM
Therock88's Avatar
Agree...I would not F' up the front of my car with a plate. The Po Po here in Illinois (some areas) take sport in giving $120 tickets for the missing front...I have paid about 10 of them on various cars, but not putting one on, until it becomes jail time or a good beating
DC
Quick Reply: 2021 front license plate removal???
