2021 front license plate removal???
#41
Thanks Stark911! The dealer told me they had to put the plate bracket on because its the law- yes well the OTHER Jag dealer and Audi dealers have all "accidently" left it off. So when I showed up for delivery they told me they would have to pull the whole front bumper. I told them hard pass. When I got home I used the your post- 10 minutes later (5 were spent trying to find my vice grips) and perfect- no more bracket. I sent this link to the service manager- LOL
#42
#43
#44
Mine is a '21. Define "bump" for me if you please. I don't know how I would angle a hammer in there given how small the clamps are and how tiny the openings on the grill are.
Also I used needle-nose pliers to turn the bolt loose so it's flush with the clamp on the outside. I can't turn the bolt anymore due to how flush it is.
walko789 (05-23-2024)
#45
Sorry- I emant a light rap on the bolt from the front as well as a light rap on the overall bracket with a hand to dislodge if needed. Maybe the bracket was overtightened originally. I found I had to use vice grips to get the proper hold. Once it was lose, I just twisted the back of the bracker with my fingers- as it was a bit of a tight fit.
#46
Here is how I removed the brackets. I used Drexel tool and cut a slot on the bolts. Then I used a small flat head screwdriver and backed the bolt out until the piece holding the bracket was loose enough to go horizontal and fit through the grill and the bracket was out. Took about 15 minutes to remove both brackets.
