2022 F-Type R - uses 1 quart oil in 1st 6000 mi.and dealer can’t find leak
2022 F-Type R - used 1 quart of oil in 1st 6000 miles and dealer can’t find leak! Says let’s see if it happens again. It’s smells of oil even at cold starts.
What do you guys think?
jcb-memphis (10-15-2022)
If it’s burning the oil; shouldn’t there be black smoke?
And, if it’s burning oil being a new engine; the engine would beyond repair ?
One quart in 6000 miles is nuthin'. Some of that usage might be from break-in. (Uses oil until the rings/valve guides 'seat'.) That amount of oil loss would never generate visible exhaust smoke.
Keep monitoring the oil level (use the car's controls to monitor prior to start-up, every few weeks). Many manufacturers still recommend checking oil & fluid levels every other gasoline fill-up...its Good Practice.
Your smell might be something different...
An Exxon oil engineer once told us that its the oil's additives that burn off first...so a bit of fresh oil on occasion is actually a 'good thing'.
355rockit (10-04-2022)
If the dealer did in fact get under the car, remove the aerodynamic panels and carefully examine the underbody for signs of oil leaks, then chances are that it burned a quart. And 1 quart over 6000 miles on a brand new engine is a lot but not excessive. Every car is different. I had a couple of cars with the Nissan VQ engines and both burned oil during the break in period and one didn't settle down and stop burning oil until about the 30,000 mile mark ! My Mazda on the other hand only burned about 1/4 quart every 5000 miles for the first 15,000 miles and now doesn't seem to be using any oil at all.
Hard to tell for sure on a Jaguar since they don't have a dipstick. How do you know for sure that it is 1 quart down from how the car was delivered ? Did the electronic gauge go from MAX to well below the half mark when always checked under the same condition ?
kb58 (10-04-2022)
I have a 2016. When I first purchased the car I was having this same issue also, the dealer even allowed me to come back to see there were no leak or oil residue anywhere beneath the car. I would say around 5k miles it stopped and from that point forward I never needed to top off the oil.
The following 2 users liked this post by F Type Terry:
Carbuff2 (10-04-2022),
Here's my bet: The dealer was still using the wrong figure of 7.25 L for your car, but since yours is AWD, it only holds 6.5. The other missing 0.25 is the dealer rounding up.
**EDIT** I just saw you say it smells of oil. Mine never has, so that is a bit of a concern, but is there any smoke? A little oil goes a long way on a hot engine.
Before I bought the Rover, thé dealer offered me a used Rover, only 12 months old, new car warranty with 36,000 miles!!! The prior owner was in sales. I would be surprised if that vehicle wasn’t returned with barely a quart of oil remaining since most JLR customers don’t check their oil and rely on the annual oil changes. Can you imagine Kim Kardashian performing weekly oil checks???🤔
I also have a v6 X-Type that I bought new 21 years ago that has 140,000 miles and has never burned oil. However, gaskets were replaced for leaks well after 100,000 miles.
The 3.8 litre XK engine in my 1966 Mk2 does need a sip occasionally, but just a sip.
scm (10-04-2022)
Hmmm, most manufacturers will tell you new engines may burn some oil until they're fully settled in (that can mean 5-10K miles. For those of us coming from BMW's that was very much the norm...more usual than not for a new car, especially M version...and they're not an outlier. I'm not even sure most auto engineers would sweat a quart every 5 thousand miles over the car's lifetime...especially if the car's driven aggressively. That is not what a manufacturer would call "excessive"...sorry, but there's overwhelming evidence that a quart for about 1000 miles for an aggressively driven car is acceptable. For owners who drive in a more relaxed manner, it's likely you'd see less consumption. Also, likely to see a bit more consumption for turbo and super charged (that's us) engines...again, especially if you're heavy footed. Finally, warm up procedure matters...take it light until the oil is on temp (not coolant, oil).
I could have asked that guy on YouTube that called his Kia a hybrid because it burns nearly equal amounts of oil and gas, but his views wouldn’t be useful.🤦🏼♀️
P.S.:An update from Jaguar is coming soon.
