3D-printed titanium wheel!
Burt Gummer (11-15-2018)
Oh it absolutely is... but when designing a car with that goal in mind, the OEM designs the suspension/chassis to match the low unsprung weight. If you throw these wheels on that weigh 3x... 4x... 5x... less than the factory wheels, your shock tuning is going to be way off and your spring rate probably would need to change too for ideal handling and ride. This isn’t something that can be easily fixed without custom shocks and springs. And even that might not be enough to get it back to stock ride. A few pounds per corner with lightweight wheels is relatively tolerable, but these wheels might reduce wheel assembly weight by over 50%, including the tires and that’s a huge change.
HRE is one of the only aftermarket wheel companies that engineers their wheels to an OEM level. They put a considerable amount of resources and testing into developing wheels for actual road use. Extensive CAD work and R&D go into each design, which is part of the reason they’re so expensive. HRE is one of the only aftermarket companies I’d consider buying from.
yes, but not too difficult to run the math and get the right spring and damping rates installed.
Still, the vid still only shows it can be done, and to what possible extend - if HRE would have created a wheel good enough for real life use, that would be shown as well.
This is imo for now at least, just to showcase HRE's skills.
One can build a rocket, but make it go to the moon is next level.
A wheel like this is not going to be installed on a bare bones, off the shelf stock shock equipped card. If you have to ask the price......
The owner will not be worrying about who cleans the wheels either. Suffice to say, These wheels will be on a rather custom application that will get pampered between drives.
