5000 mile update
It's time for the F to go in for maintenance and service. Here's the list:
1. Very squeaky brakes... like embarrassingly squeaky at slow speeds. I mentioned it to the service advisor on the phone, and he seemed rather indifferent to the problem, saying that it is very common with the V8 models. Hopefully they can do something about it.
2. grabby left brake. If I tap or hit the brakes the steering wheel will lurch slightly left, as if the left brake grabbed faster than the right one. Kind of annoying. Not sure what the fix will be.
3. occasional screen blanking. The entire screen will go blank, even though everything else is working. It seems that if I tap the screen in the exact right spot for functions, it will actually work. So it's recognizing touch input but not displaying anything. When I mentioned this to the service advisor he told me that if he can't duplicate it during the service, then he won't be able to do anything. That's kind of irritating but we'll see. Unfortunately, this only happens about once every couple of weeks. The good news is, it happened yesterday....so I whipped out my iPhone and took a video of it. Hopefully this is good enough for him to do something about it.
2. grabby lift brake. If I tap or hit the brakes the steering wheel will lurch slightly left, as if the left brake grabbed faster than the right one. Kind of annoying. Not sure what the fix will be.
My experience with Jaguar service managers is that they are usually a lot more helpful and 'can-do' than the one you are dealing with.
Hope it all gets fixed for you without too much hassle... the video seems like a good idea.
Lawrence
Bobby,
for your squeaking brakes, I have the same issue from time to time but find it to be attributable to brake dust accumulation. After a decent wheel/brake clean the problem goes away. These cars have huge brakes which are tremendously effective but throw off a lot of brake dust. Based on my own experience, I'm confident that my issue is dust accumulation and nothing more troublesome.
For your display issue, I had a slightly different but probably related issue. My screen would fail to start from time to time, by which I mean it would just not power up - the backlight would not fire up, the display was powered off and it was unresponsive. In my case, the dealer (thankfully) DID reproduce the issue and raised it with Jaguar. The factory told my dealer that they were aware of this issue, and that they had developed a software update that addressed it. They sent my dealer the new software, and so far the problem has not returned. Push this with your dealer. It may be that your issue is connected to mine, and Jaguar IS aware of the issue and HAS developed a fix.
Keep us posted!
Keep us posted!
Known issue with JLR Info system since 2013 and software fix
When I bought one of the first XJs that was plagued with issues, they could never duplicate anything... So I started video taping everything. I kept a camera nearby and often times, turned on when I started the car just in case. I got fifty some odd videos and ultimately, a new vehicle since the gremlins in the car were so bad.
Ok, the F is sleeping over at the dealer tonight. I have a XF loaner (Odd loaner policy at this dealer... it's through Enterprise so I have to pay $100 but then later be refunded.) It's fun to see the differences among models. Brand new car with 1400 miles. It's very quiet and comfortable. Very sluggish when accelerating out of a turn unless I force a downshift (or two). Sound system sounds loads better than my optional system in the F. No rattling bass... imagine that! The vents "disappear" by flipping around when not in use, which is almost as silly as the ones that rise out of the F-type dash. The dial for gear selection is just plain weird and not intuitive at all. The screen is too small. The car refuses to lock and unlock without using the keyfob despite having keyless ignition. This may be a settings issue. The indicated average MPG is 19 which is worse than my F-type but this may be because people drive rentals hard. Is this post boring?
Mine is going in for the 1 year scheduled maintenance next week, at around 8600 miles. Conveniently, the check engine light just came on for the second time. The first time was right after I took it out of winter storage, and they had to replace an O2 sensor. They also did software upgrades, and a fix to the roof to stop uneven wear (they moved a harness.)
I just checked the oil level, and it still says 'full', which is nice.
Am hoping they do something nice with the XE, but the spy shots look undistinctive. The new XK could borrow some lines from the F-Type.
FS[Canada]: Vancouver BC FType lease takeover
nd143
09-03-2015 04:42 PM
