719 horsepower F Type R
Old 11-25-2023, 04:11 AM
pab74's Avatar
Default Product pitch
Originally Posted by Stuart@VelocityAP
Stuart,
First, thank you and the team for everything you do for our platform.
The Allisport is a very nice unit. I installed mine just to have an all-aluminum unit removing one plastic/potential weak point from our current cooling system.
If only there was a company that offered an all-aluminum radiator and a coolant pipe replacement kit that we could trust.
Old 11-25-2023, 06:05 AM
mecheng1's Avatar
Originally Posted by inmanlanier
By definition 'keeping the charge temps down' adds more power. Temperature directly correlates to density. Higher density of air means more O2 per mole of air moved through. More 02, more HP.
surely, you mean more moles of air moved through, not more oxygen per mole?
Old 11-25-2023, 07:29 AM
bfrank1972's Avatar
that's the idea, but it so can be more complicated than just bolting on a larger/more efficient intercooler. You often lose psi, so cooler charge at somewhat less psi means less flow of denser air - often results in nominal gains and sometimes loss without re-tuning (fuel mapping, ignition advance) plus pulley change. Any significant airflow change in the "system" usually requires re-tuning the whole system. Also we should factor in the max speed of the blower itself - even if you're compensating for additional heat from driving the supercharger faster, you may get diminishing returns as the SC itself will become the limiting factor and overdriving it may reduce its service life. Then you need to consider at least porting, if not moving to a larger unit. Slippery slope!
Old 11-25-2023, 07:51 AM
RGPV6S's Avatar
What is all this talk about moles and oxygen?
Just kidding I am a chemist and couldn't resist.
Old 11-25-2023, 12:28 PM
clubairth1's Avatar
Received 2,457 Likes on 1,931 Posts
Thanks Stuart! Your right it's Allisports that make them!
I don't see any dimensions on the wraptor and it looks identical to the Allisport version except for two small tabs sticking out the top?
Does not look larger than the Allisport either?
Can you post dimensions as the web site seems to have left that out?
Here is the difference in thickness between the stock Jaguar IC and the Allisport aftermarket one.
Old 11-25-2023, 04:14 PM
Gasman2's Avatar
The wraptor one is 2inches deep I think and Def larger than the allisport one
Old 11-25-2023, 05:43 PM
Wraptor Baby's Avatar
Hi, I've been asked to join the thread. I think ref thickness/quality of the cooler?
Let me know if you need anything.
Couple of pics attached of our quality extra thick cooler, hand fabricated in the UK, pressure tested, supporting the other parts we've developed. VS another supplier, I believe is made in China.
We have the option to produce in China at seriously reduced costs. But by decision is to retain the quality and keep it in house.
The following 5 users liked this post by Wraptor Baby:
Dale Melton (11-26-2023), Gasman2 (11-26-2023), Quan Jordan (11-26-2023), Supersprint Sport Exhausts (11-25-2023), Turko (11-25-2023)
  #28
Old 11-26-2023, 04:21 PM
Dale Melton's Avatar
Wraptor one defo looks better to me. 'They've got my vote.
Old 11-26-2023, 04:25 PM
Gasman2's Avatar
Yep wraptor slots straight in
Turko
10-23-2023 08:50 PM
Turko
07-12-2023 05:20 PM
malbec
03-15-2021 07:58 AM
Satdiver68
02-15-2015 04:48 AM
JimC64
12-26-2014 08:54 AM
Quick Reply: 719 horsepower F Type R
