Active Exhaust
Old 06-22-2017, 06:25 AM
PhilGez's Avatar
Default Active Exhaust
Hi everyone - newbie to the forum. Ive taken receipt of my new amazing F type base model a few months back (polaris white 20" wheels and black pack) and keeping my message short It didn't have the 'active exhaust' button on it. Now the sales person told me that the valves open at 4K rev etc and in sport/dynamic it makes a mighty noise but I just cant get over the fact I should have gone for the button (its a long story why) ... what can I do ? ive asked Jag and they say they do not retrofit and provide no options - is it possible ? please help ...
Old 06-22-2017, 10:30 AM
WhiteTardis's Avatar
From a mechanical standpoint..its too cost prohibitive to retrofit an active exhaust system on to a car without it. You would need to source:
-Rear muffler assembly
-Vacuum lines
-Exhaust button
-And depending on the year you got; a vacuum pump.
-This doesn't include modifying the cars' configuration software files
Old 06-22-2017, 11:24 AM
Unhingd's Avatar
Received 4,661 Likes on 3,366 Posts
-Vacuum lines
-Exhaust button
If the car sounds louder over 4000rpm, he may have active exhaust, but not the switchable active exhaust. I suspect the valves will stay open all the time if the car if the car is in dynamic mode. If PhilGez does have the active exhaust, Stuart at Velocity AP can set him up with a remote control that will open and close those valves.
If doesn't have active exhaust, the base exhaust system is almost as loud as the active exhaust with the valves open (doesn't sound like this is the case).
Old 06-22-2017, 11:34 AM
DJS's Avatar
DJS
DJS is online now
Received 2,106 Likes on 1,406 Posts
On my 2014 V6S, with active exhaust but not switchable active exhaust, the valves are not open all the time in Dynamic - depends on throttle, RPMs, etc. I can hear them slowly open when I put my foot down.
I can't keep track of what's standard/option/not available on base models, as it changes by year. But generally, active exhaust hasn't been standard on base models.
Old 06-22-2017, 11:40 AM
F-typical's Avatar
If he does have the plumbing, all that's required is the switch (and possibly a tweak to the CCF)
Old 06-22-2017, 11:51 AM
Unhingd's Avatar
That's the challenging part. Better to just remotely switch the valves independently of any computer intervention.
Old 06-22-2017, 01:57 PM
ek993's Avatar
If you do have the active exhaust, and don't mind it being in noisy mode all the time, pull fuse F43
superq7 (07-03-2017)
Old 06-22-2017, 02:21 PM
DJS's Avatar
DJS
DJS is online now
Wonder if that works on newer models that don't have the vacuum pump, i.e. does the fuse power the pump, solenoid, or both?
Old 06-23-2017, 01:31 PM
Jagged Wire's Avatar
My thoughts: It would seem kind of silly for Jaguar to make just a few mufflers without the plumbing for just those few cars that don't have the active exhaust (button). So I also think a switch and connecting it up and possibly doing something to the computer is all that's necessary. That's my guess.
I know its apples and oranges but on some Mustangs without the fog lights, the harness is there.
I asked a service writer at my dealership. I don't remember them saying they can't or they won't.
Old 06-23-2017, 01:56 PM
DJS's Avatar
DJS
DJS is online now
There are 3 levels:
No active exhaust (no vacuum pump, no solenoid, no valves)
active exhaust (without the switch - what I have)
For active exhaust without the switch, it's computer controlled, depending on throttle position, engine speed, etc. It's only on in dynamic mode.
Old 06-23-2017, 02:13 PM
Originally Posted by DJS
There are 3 levels:
Ohhhh. Thanks very much. Good info. So now, how do I know whether I have #1 or #2? Just step on the gas past 4000 rpm in dynamic mode? My car was built mid 2013.
Old 06-23-2017, 02:38 PM
Not to toot my own horn but I've done extensive work for aftermarket exhaust options for the V6 F-TYPE. Base cars have their own unique muffler assembly meaning no valves, plumbing, etc. Based on your statement without running your VIN to get the buildsheet..you more than likely have option #2. I've attached links to all my exhaust related threads.
https://www.jaguarforums.com/forum/f...-go-do-144784/
https://www.jaguarforums.com/forum/f...-v8-v6-150072/
https://www.jaguarforums.com/forum/f...t-done-171467/
Old 06-23-2017, 03:41 PM
DJS's Avatar
DJS
DJS is online now
Active exhaust is standard on the V6S, switchable active exhaust is an option. At least it was for MY14 - think that's still the case.
BTW, 2014 Salsa Red V6S's rule.
Jagged Wire (06-24-2017)
Old 06-23-2017, 06:36 PM
Unhingd's Avatar
Just look under the car. If you have the active exhaust, you will see the valves sticking out of the side of the two pipes just before the muffler.
Old 06-24-2017, 06:15 AM
F-typical's Avatar
...and there will be 4 pipes going into the muffler...
Old 06-24-2017, 06:20 AM
F-typical's Avatar
At the risk of thread hijack, the pumped option appears to have an accumulator (pressure reservoir) as part of the pump assembly.
Does the option that runs off manifold vacuum do the same, or just run a pipe to the exhaust valves?
The e46 shopping car has an active exhaust that just runs off manifold vacuum with no electrical gubbins whatsoever.
Old 06-24-2017, 06:49 AM
RGPV6S's Avatar
I think the 2014 Firesand ones do too! Actually its known fact that all orange cars go faster.
BTW My V6S has the switch - and it goes faster.
Old 06-24-2017, 03:16 PM
Yup, I've got the plumbing. I put it in dynamic mode and used the flappy paddles. Gunned it, shifted it up a couple gears, let off the gas, and ohhhhhhhh that sounded nice.
Old 07-03-2017, 08:57 AM
PhilGez's Avatar
Thanks for the helpful responses all. Its a 2017 purchase (in other words Ive had it about 5 months now straight from the garage) and I believe (least what they told me) is that I do have the active exhaust just not the switch to activate. In dynamic mode above 4K revs its sound beautiful Im assuming that with the switch even at low revs it sounds like that all the time ? is that correct ? surely it cant be that difficult to fit the switch but Jag were not playing ball.
Old 07-03-2017, 10:56 AM
superq7's Avatar
Just pulled the fuse on my new convertible and BINGO!!!!!! loud exhaust all the time, thanks ek993
Quick Reply: Active Exhaust
