Active Exhaust
Active Exhaust
While I realize exhaust tone is a subjective item, I am having difficulty with the Active Exhaust Control.
My 2021 R-Dynamic ( 6 cylinder) has the active exhaust switch which illuminates when pushed or when the sport mode is selected.
I have driven the car 15K miles and I am unable to hear any difference in exhaust tone activated or not.
The exhaust tone does sound pretty good - not much in the way of pops but a healthy growl when the pedal is pushed.
There just does not seem to be any difference active or not
I read that JLR muted the exhaust prior to 2021, but would still expect some discernable note/decibel change when active.
Is it likely the Active Exhaust is stuck in the ON (or OFF) position?
I thought I would mention this at the next JLR service in January but would appreciate comments .
Depending on the MY the exhaust switch behaves differently. In my MY18 if I select dynamic mode I can immediately hear the difierence. but if out of dynamic and with the switch on it doesn't kick in until 1500 rpm. Other MYs open the valves at tickover on the switch. My valves will always open around 4000 rpm regardless of the mode. As they say, YMMV.
Yesterday I drve 150 milwes alternating sport mode with regular mode with/without the active exhaust switch on.
Totally unable to distinguish a difference.
Today I removed fuse 15 and hard revved in park - no diference with or without the fuse.
Car is booked in for service in a couple of weeks.
I will report back when I know anything.
ps I did manage to drop/lose two of those fiddly screw clamp backers from the cover plate over the fuse box!!
Hopefully JLR will replace
AIUI, sport and regular mode make no difference to the exhaust sound, apart from sport potentially riunning higher revs so you might stray into 4000+ rpm territory more. It's dynamic and non-dynamic that makes the difference (and the switch). Assuming everything's working as it should, which doesn't appear to be the case for you. Hope you can get it sorted out satisfactorily - good luck!
Yes, MoJo. Sorry it was not clear in my later posts. It made no difference.
And, SCM: I meant dynamic not sport mode.
I am sure there is an issue - just not clear whether valves are stuck open or closed.
It appears a vacuum leak would leave the valves open for more volume.
I've just remembered there is a difference between sport and regular drive mode - you can use the stick instead of the paddles to shift gears manually! Oh, and you can configure the paddles to be active in both D and S, or just S.
photos of valves and lines/hoses
Sorry this took me a bit.. work gets in the way Ya know?
The first photo is an orientation shot, so you can see where the "cans" are in relation to the rear tires and gas tank. The photos I took are of the right rear.
The next two are closeups of the "cans', the control units for the AE. Check the vacuum lines to make sure they are on. Hope this helps.
At least with my 2020 R the valves are open prior to startup and then they close when vacuum is generated. The engine should be loud initially and then quiet a bit a few seconds after startup, indicating the valves have closed. When Dynamic or the active exhaust system is engaged it will open the valves under hard acceleration. Disconnecting the fuse that control's the active exhaust system will cause the valves to remain open all of the time regardless dynamic mode of the button status. Those fuses have changed fuse box locations I believe over the years but it's #15 in the engine bay fuse box in the 2020 R.
