Active exhaust valves fuses F43 F15
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
This morning i tried removing the F43 fuse to keep the exhaust valves always open on my 2017 F-Type 3.0 S, but nothing changed.
I then discovered that on 2017+ models there are two fuses for active exhaust: F43 and F15.
Anyone knows what F43 and F15 respectively controls?
Do I have to remove both? Or F15 only?
I read in other posts that removing F15 will put the car in Limp Mode.
So anyone knows a way to keep the exhaust valves open all the time?
I am thinking of disconnecting the tubes connected to the valves, but I don't know if I have to close them in some way.
This is my Active exhaust control solution. Same concept as the mild to wild remote switch for the Corvette active exhaust valves.
https://www.jaguarforums.com/forum/f...e-43-a-213500/
See post #17.
Believe me when I say, once you do this you will change your mind about needing to replace the exhaust system. Decently tame but when you get into it very noticeable. Paddle shifting through the gears is a whole different story, very cool. This mod gives you the ability to return thing back to the cars active exhaust control at any time you desire.
See post #17.
There are times when I just want to travel home in stealth mode, being a red F-Type with a carbon fiber spoiler alone draws attention, the last thing I need at times is to be making racket.
The button is the cat's ***.
My Owners Manual for my 2021 type R has a schematic of the 3 fuse boxes in the car. Each of the fuse positions are numbered and the Manual identifies each of those positions, the fuse rating and what function runs thru that fuse. #15 clearly shows it is the active exhaust valve system. It appears the valve is spring loaded to have the valve wide open and the valve modulates towards the close position depending on several variables...speed, rpm's, fuel flow rate, driving mode, etc. If the Jag system is the same as the C7 Corvette system, the valve never "always" stay open, regardless of what mode you are in (normal, sport and track)....track is certainly the most aggressive and the valve is open most of the time, but given the right circumstances, the butterfly will briefly move toward the closed position. Pulling the fuse is the only sure way that the valve stays wide open....no power to move the valve butterfly and it's spring loaded open.
Along the way, someone asked if operating the car with the subject fuse pulled could damage the catalytic convertors. I can't see why it would and never experienced any problems with the fuse pulled in my C7 Z06, but am I missing something with the type R?
Fireze22 (08-24-2021)
![Icon Angel](https://www.jaguarforums.com/forum/images/smilies/icon_angel.gif)
I have a 2021 5.0 V8 (not R), when I Start the engine with open valve (exhaust button pushed), you can hear the high sound exhaust and if you give a bit of gas after the first roar start or if you starts immediatly, the exhaust valve stays open only for a while making the tipical nascar sound, then the valve closes and silences the engine.
I have a 2021 5.0 V8 (not R), when I Start the engine with open valve (exhaust button pushed), you can hear the high sound exhaust and if you give a bit of gas after the first roar start or if you starts immediatly, the exhaust valve stays open only for a while making the tipical nascar sound, then the valve closes and silences the engine. Only after 3300 rpm the valve reopens. So I suppose like you there is a spring exhaust valve . So lets pull the fuse 15. We need to test first to confirm![Icon Angel](https://www.jaguarforums.com/forum/images/smilies/icon_angel.gif)
If you press the button at this point it it will flash on and off a few times and then turn off completely, you will also hear the simulated exhaust tones inside the car turning on and off quickly in concert with the flashing light on the button. This will be extremely obvious if you have added and aftermarket subwoofer to your audio system. Probably will be a bit more suttle with the factory speakers. The active exhaust system will not not be able to be turned back on without fuse 15 installed at this point. If you press the active exhaust button with fuse 15 removed the light will flash on and off and you will again hear the simulated exhaust tones turning on and off as well. This is for the 2020 R 5.0.
I am sure that dynamic mode is changing other attributes of how the exhaust valves open and when but since i have install the modification to turn on and off the exhaust valves at will, they generally stay fully open at all times.
There may be slight differences with other years but this is the way it is on the 2020 R. Should be easily verifiable on the other model years.
DJS (08-19-2021)
My 2021 has no simulated engine sounds inside the car. The “loud” button does open that valve, but I have no idea after the car warms up, the degree to which the butterfly stays at full open…it sounds like there is some modulation while you’re driving with the loud button on and opens wide when you floor board the accelerator. I am quite certain the valve stays wide open all the time when the fuse is pulled in my car.
But, I’m still curious what the other motor heads think about the catalytic converter potential failure comment that I mentioned in my previous post.
Well seeing as the valves are downstream from the cats I'm not sure how always open would affect the cats at all, unless you argue that it's constant reduced backpressure or even a slightly lower temp for the cats. However, these are so minor I can't imagine it having any detrimental effect on the cats.
