Adapters/wheel spacer 20mm
New to the jag f type, and would like to know if 20mm adapters/ spacers would fit all around? I would like to apply a more flush look.
I'm reaching out to see if anyone has any experience with this or has integrated spacer applications of their own- if so what size(s)?
Lastly, I like to achieve this look with NO modifications.
Please advise and thank you all in advance!
Received 3,209 Likes
For stock 20" wheels set-ups 17 mm is about the limit on the front but 20 mm on the rear is no problem at all. I have 15 mm front and 20 mm rear spacers with VAP lowering springs and stock 295/30ZR20 rear and 255/35ZR20 front tyres on stock wheels (Blades) therefore stock offsets and I have zero problems and zero rubbing even over large bumps and dips.
Craaaazzy is right about the need to cut/trim/grind the studs though, for every stock F-Type wheel EXCEPT the Blades.
