Adding front camera
Planning to add a front facing camera in the grill / spoiler area of my 2017 SVR to help with close-in parking and avoid scraping the fender lip on low curbs. Bought one that sends wireless signal to a mini screen I can keep in center armrest. So the camera only needs ignition switched power
Any advice on where / how to route the wire from front of car into engine bay - and best place to tap into ignition-switched 12V power?
Separately - as an alternative has anyone put the Nav-TV or similar setup to add a front camera directly into the touchscreen? It looks neat but am guessing it's much more involved to route a camera wire through engine bay and into back of touchscreen area? And not sure if it works on 2017 - am asking them for info
Thanks!
Thanks!
This is a project I am hoping to tackle as well once I splurge on an Android head unit. The 360 camera seems nice but I'm not too keen on drilling the side mirrors and routing wires from there.
There are wireless cameras all over ebay that I was considering for this, it seems like there is some space behind the head unit that you may be able to tuck a module into. Something like this, which I found in 30 seconds and I'm sure you could do better than with a bit more searching. Many of the units also allow you to cut a wire to disable the 'track' on the camera. Given the atrocious quality of my backup camera on my 16 (hey.. at least it works right) I'm not too concerned with resolution for the front one.
Tapping the head unit power itself for this module seems reasonable, which leaves only the camera itself to be powered by a switchable source as you say, which I haven't figured out yet.
Thanks!
Thanks!
Mark7Seven (10-20-2021)
