Affordable Flow-Formed Wheels for your F-Type: VelocityAP Partners with APEX
#41
That's yet to be determined, but will be part of the prototype & test fitment process. It has to be looked at along with planned camber settings (almost all responded they would be running stock camber) so it's likely it would fall in the range of 10-15mm more offset that equivalent OEM fitments of the same width. For example an OEM 20x10.5 would be an ET38, we'd probably look at something in the ET25-ET28 range for a 20x10.5 so it has the equivalent 'flush' of an OEM wheel with a 10-15mm spacer.
__________________
Stuart Dickinson
Managing Director
VelocityAP Industries Ltd.
O: (1)250-485-5126
E: Stuart@VelocityAP.com
www.velocityap.com
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
#42
#43
Ah ok! Great looking wheel!
I'm confused about the wheel widths. Why wouldn't we be running the exact SVR widths and offsets to be ''safe''? Doesn't that make the most sense?
Anyway, looking forward to owning a set of APEX wheels for Jaguar as I think they are great value.
dwmilton (05-24-2020)
#44
So there will be some additional checks and so on. Offset is a part of that. Typically aftermarket wheel buyers are looking for a more flush offset, and generally it makes sense to build those offsets into the wheel rather than needing spacers. In this case there is no way we'd go so aggressive that you need for example, 2.5 or 3.0" negative camber in order to clear the fender (some of their other applications that are track targeted would require this.) That said, running an additional 10-15mm of 'poke' in a fitment that works on an lowered car with stock camber is likely to be quite attractive.
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
#45
#46
#47
The following 2 users liked this post by MisplacedPriorities:
dwmilton (06-19-2020),
supersportmtl (05-27-2020)
#49
No test fitting going on at the moment. The engineering team at the wheel factory had to clear some things off their plate prior to starting work on this, and there is some decision making going on regarding tooling.
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
#50
#52
We aim to run a group buy/pre-buy at the time that we decide to proceed so there will probably be an opportunity to pre-order them at the time that fitment is confirmed and signed off.
Apex needed to clear off some existing engineering workload, but are now tackling this project. Because there are certifications involved, there are a number of processes and procedures that need to be followed and completed. We are aiming for sign-off on the wheel this fall, with production complete and order delivery in January.
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
dwmilton (06-25-2020)
#53
Thanks for the reply. I'll stay tuned for details as the develop. $650/wheel seems relatively high for flow formed wheels...these aren't forged, correct? I'm coming from the VW/Audi world so maybe there is some Jaguar tax in there
#54
We are simply anticipating some slightly higher costs and being realistic about pricing. I'm not going to BS people that it will be $1900 and then it turns out to be $2500, so we are trying to anticipate some additional costs related to a new size & style. I'd much rather come in under what we estimated than over. And there certainly will be a deal on pre-purchase.
That said, yes they are flow-formed, but I don't think that the pricing is unreasonable for the quality. When you compare it to Audi you're comparing to a market that has significantly higher volumes and economies of scale associated. There's not some unreasonable profit built into this, and if I'm being perfectly honest it's something that I engaged in because I thought that bringing a high quality, lightweight, off the shelf fitment wheel to market for the F-Type was something the community was lacking.
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
#55
I don't disagree with anything you stated, except that there is indeed a premium associated with a low volume, essentially boutique item like this. I didn't mean to imply there was some exorbitant profit built into the price. At least they aren't $2500/each HRE forged wheels. Sorry if I offended.
There's no Jaguar tax at all. Apex pricing for 19x10 & 19x11 for a Mustang for example is around $1900 for a set. They do not make 20" wheels right now, so there are additional tooling costs to consider, specifically if we opt for a PS7 which may not be something they see themselves using for other vehicle fitments. And being a slightly larger wheel there are likely to be slightly higher costs.
#56
I don't disagree with anything you stated, except that there is indeed a premium associated with a low volume, essentially boutique item like this. I didn't mean to imply there was some absorbent profit built into the price. At least they aren't $2500/each HRE forged wheels. Sorry if I offended.
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
#58
#59
The project is in the engineering phase. Design, testing & certification all have to take place. We expect by the early fall, to have samples for test fitments, and aim for first production order deliveries in Jan 2021.
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
supersportmtl (07-14-2020)
#60
