After everything I just finished, it spun a bearing
Just recently completed replacing the spark plugs and fuel injectors on my V6S and have been enjoying having it back on the road. This past weekend, I heard what was at first a slight tapping from under the hood. I checked the oil level and got the "below minimum" message. I have no idea how it was low on oil, but it was, and it was my fault for not checking it before getting back out onto the road. I added a quart and drove it a bit, but the sound persisted. Checked the oil level again and received the same message. I added a second quart and it came up to the middle portion of the oil level graphic. That means it was somehow more than two quarts low and there was no check engine light or warning light to alert me to how low the oil had gotten. The tapping turned into a clattering, so I pulled into a gas station and called for a tow.
Now I'm trying to find someone who can rebuild the engine, but because it's a Jag and I live in the south where Chevy and Ford are king, I'm having zero luck. It's looking like I'll have to purchase a used engine and swap them out.
After the ordeal I went through to get the injectors swapped out, I feel completely gutted about this. I have no idea why there are no low oil warnings built into this car, but there aren't. Be vigilant about maintaining your oil levels, don't make the same mistake that I did.
Received 3,209 Likes
Couple comments:
Oil might have been low from fuel injector getting stuck
Are you sure the injectors you have are good? It is possible that noise could be a result of faulty/stuck injectors
Until you see metal in the oil, don't assume it is spun bearing.
Anecdote: A while ago a family member's old car started to make spun bearing noises. Knowing car's mileage and lack of care, I immediately assumed spun bearings. Turns out it was one of the belt pulleys that was making atypical noises. Huge egg on my face.
I agree with SinF and Obi. Check the things they suggested first. Also a loose spark plug sometimes makes a clacking or tickling noise as does a broken/loose exhaust manifold bolt/cracked exhaust manifold.
BTW just ran out to the garage and checked the oil level in the Jag.
