After Market Back up camera again
I spoke with the NAV-TV folks and they sent me a link to a YouTube video they did showing an install on an F Type. It appears from the video that even if you bought your F Type without a backup camera already installed, that their system can plug in and activate both a front and rear camera via the existing display interface in the car. I have the rear view camera option on my car and want to add the front camera to protect against curbs and concrete tire-stops from beating up my front splitter.
I contacted my local Jag dealer and the service manager finally responded that they would not do the install because they thought they might have liability if I had an accident since the cameras could be activated while the car was in motion. They are correct in saying that the cameras can be accessed while in motion but the OEM system for reverse camera works that way now! I am not going to argue with them because it's obvious they are not interested in servicing me and not being able to charge me for an OEM equivalent product.....they would only be making a mark up on the labor. The video attached makes it look pretty easy! if you have any questions you can call Tony Yankovsky with NAV-TV at (954) 323-1010 x105 to discuss.
Yes. I think they should have a version of the kit that also includes the front camera and installation instructions.
#31
what camera(s) are you guys using?
trying to see how much the whole kit will cost, NavTV plus 1 or 2 cameras...and if pro installation is needed or if it can be DIY'd ... or go with the Pearl RearVision for $425, no installation required, camera powers off solar power, but it does transmit the feed onto your smartphone so you have to launch an app each time which is kinda annoying/ghetto lol
#32
#33
even if its plug n play and reversible, in 3 years it will be worth maybe $200 as a complete kit in the classifieds section
#35
#36
Does anyone know if the cam mod is required to connect the rear view camera to the screen? Could I just connect it directly? If so, would it activate only when the car is in reverse?
#37
Mine (NAV-TV) didn't require any mods, and automatically goes on in Reverse, then shuts off when Drive is selected.
#38
#39
So to clarify, I am asking how to avoid buying that NAV-TV module. I want to just buy a camera and connect it to power and the purple connector on the back of the screen. That would save me the cost of the NAV-TV module, but how could connect the rca cables from the camera to that purple input?
It's not plug & play, a software change is needed to get it working.
I have done the same thing on a couple of cars, including my XKR.
You can get adaptor cables that go from Fakra to RCA, I made my own (making cables is a hobby of mine LOL)
#40
What you want can be done. It all boils down to planning. My approach would be to have the cars schematic and the camera's schematic and do your planning on a table. That way you can do your planning comfortably and insure you are error free. It is also helpful to have a complete schematic at a later date for fault finding.
I was going to convert my Lexus GPS into a video (movie) display, but after doing the above planning I found it was complicated and expensive and gave up the Idea. Good luck with your project.
