After Market Back up camera again
Old 04-22-2015, 03:27 PM
RobsnTX's Avatar
I spoke with the NAV-TV folks and they sent me a link to a YouTube video they did showing an install on an F Type. It appears from the video that even if you bought your F Type without a backup camera already installed, that their system can plug in and activate both a front and rear camera via the existing display interface in the car. I have the rear view camera option on my car and want to add the front camera to protect against curbs and concrete tire-stops from beating up my front splitter.
I contacted my local Jag dealer and the service manager finally responded that they would not do the install because they thought they might have liability if I had an accident since the cameras could be activated while the car was in motion. They are correct in saying that the cameras can be accessed while in motion but the OEM system for reverse camera works that way now! I am not going to argue with them because it's obvious they are not interested in servicing me and not being able to charge me for an OEM equivalent product.....they would only be making a mark up on the labor. The video attached makes it look pretty easy! if you have any questions you can call Tony Yankovsky with NAV-TV at (954) 323-1010 x105 to discuss.
Old 04-22-2015, 04:19 PM
DJS's Avatar
DJS
DJS is offline
Received 2,106 Likes on 1,406 Posts
I looked through the install document, and it didn't look terrible. Except you'd have to install the front camera, which may or may not have harnessing in place. And a way to mount it.
Old 04-22-2015, 04:24 PM
DuhCar's Avatar
Yes. I think they should have a version of the kit that also includes the front camera and installation instructions.
Old 03-20-2017, 10:30 AM
supercat'dXKR's Avatar
does it require you to splice wires in the tail lights to activate the camera when put into reverse?
Old 03-20-2017, 06:04 PM
Youngguns27's Avatar
No I just had the NavTv just installed with a backup and forward facing camera. It works flawlessly
Old 03-20-2017, 06:11 PM
WhiteTardis's Avatar
Can you clarify what year F-TYPE you have? The installation directions for 2016+ are slightly different than 2014-2015 as there is some tapping involved.
Old 03-20-2017, 06:12 PM
I don't know if you guys noticed but the installation instructions for 2014-2015 and 2016+ are slightly different.
  #28
Old 03-20-2017, 06:21 PM
I have a 2016 F-Type S AWD
Old 03-20-2017, 10:26 PM
is this an easy DIY?
  #30
Old 03-21-2017, 12:27 AM
I had a pro installer but he said it is easy the hardest part was pulling the trim off around the lcd screen without marking is the hardest part. Its plug and play and no splicing
  #31
Old 03-21-2017, 12:59 AM
what camera(s) are you guys using?
trying to see how much the whole kit will cost, NavTV plus 1 or 2 cameras...and if pro installation is needed or if it can be DIY'd ... or go with the Pearl RearVision for $425, no installation required, camera powers off solar power, but it does transmit the feed onto your smartphone so you have to launch an app each time which is kinda annoying/ghetto lol
  #32
Old 03-21-2017, 09:30 AM
FullChat's Avatar
My Nav-TV pro (recommended by Nav-TV) installation with both cameras on a Base was $1200.
  #33
Old 03-21-2017, 10:37 AM
damn! $1200 is a pretty penny considering im leasing the car...
even if its plug n play and reversible, in 3 years it will be worth maybe $200 as a complete kit in the classifieds section
  #34
Old 03-25-2017, 08:58 PM
Coopersjag's Avatar
This would be such an easy DIY job. Set aside a day if you are new to this kind of thing, buy some simple tools and save yourself $600.
  #35
Old 03-26-2017, 12:12 AM
Any DIY write ups?
  #36
Old 08-09-2017, 02:34 PM
shayknbake's Avatar
Originally Posted by afterburner1
You can mount a license plate camera on front and rear or both. If there is only one jack point, a double pole double through switch solves that problem
Does anyone know if the cam mod is required to connect the rear view camera to the screen? Could I just connect it directly? If so, would it activate only when the car is in reverse?
  #37
Old 08-09-2017, 02:42 PM
FullChat's Avatar
Mine (NAV-TV) didn't require any mods, and automatically goes on in Reverse, then shuts off when Drive is selected.
  #38
Old 08-09-2017, 03:15 PM
shayknbake's Avatar
Originally Posted by wcben
that switch won't help you get the screen to change and would only work while the car was in reverse.
So to clarify, I am asking how to avoid buying that NAV-TV module. I want to just buy a camera and connect it to power and the purple connector on the back of the screen. That would save me the cost of the NAV-TV module, but how could connect the rca cables from the camera to that purple input?
  #39
Old 08-09-2017, 03:25 PM
Received 4,454 Likes on 2,426 Posts
To feed a camera signal directly into the back of the touchscreen (and have it working) you need to modify the Car Configuration File to enable the reversing camera.
It's not plug & play, a software change is needed to get it working.
I have done the same thing on a couple of cars, including my XKR.
You can get adaptor cables that go from Fakra to RCA, I made my own (making cables is a hobby of mine LOL)
  #40
Old 08-10-2017, 12:41 PM
afterburner1's Avatar
What you want can be done. It all boils down to planning. My approach would be to have the cars schematic and the camera's schematic and do your planning on a table. That way you can do your planning comfortably and insure you are error free. It is also helpful to have a complete schematic at a later date for fault finding.
I was going to convert my Lexus GPS into a video (movie) display, but after doing the above planning I found it was complicated and expensive and gave up the Idea. Good luck with your project.
Quick Reply: After Market Back up camera again
