Aftermarket CATS
You might be best to just get a set of 200 cell down pipes from VAP. No welding, just bolt up. That would’ve easily allow you to put the OEM pipes back in if you need to get the car tested.
Even though it’s not legal in Cali (no CARB number), it should still pass basic smog. Not sure about STAR smog.
A good quality Motorsport cat is going to run you around $200 (x2), the OEM tube size is metric but roughly 2 1/8", so you'll need one with cones down to that size or smaller. 4 O2 bungs for pre & post cat sensors and I would estimate about 4-5 hours labour to remove, cut cats out, mock up and weld. For good quality fab, parts & tig welding I would plan on spending about $900-1000.
__________________
Stuart Dickinson
Managing Director
VelocityAP Industries Ltd.
O: (1)250-485-5126
E: Stuart@VelocityAP.com
www.velocityap.com
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Unless you do some crazy fabrication work you'll need to replace both primaries and secondaries at the same time, they are integrated into the same canister.
Ours are a direct replacement for the entire catalyst/downpipe assembly. 100% reversible, no cutting/welding, very quick fitment.
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
p-Rock
09-04-2017 03:36 AM
