Aftermarket Exhaust/Muffler - should you block the valve vacuum lines?
Hey all
When you fit an aftermarket exhaust / muffler, what should you do with the vacuum lines that switch the exhaust valves? (that are now redundant) Should you block them off or just leave them open?
Thanks in advance
Thanks in advance
Any idea if you have the electric vacuum pump, or a vacuum line running back from the engine? Think it was either MY16 or MY17 here (MY15 or MY16 for you, I think) when they got rid of the vacuum pump.
I would probably plug the lines if you think they might ever be used again. If you have the vacuum pump, I'd pull fuse F43, which powers down the pump and solenoid.
The is for MY14 here (your MY13):
https://www.dropbox.com/s/szc3vze5ol...haust.pdf?dl=0
Pulling the fuse or disconnecting anything will result in a trouble code (it does if I do that on my 15).
Plug the line. It's not intended to be free breathing sucking on atmosphere all the time... plus the pump would be running nonstop if you have the pump, or until perhaps it times-out.
