Air Vent stopped raising.
I'm guessing xfactor is talking about the range within which the temperature is allowed to drift. For example, set the temp at 72, ac goes on until temp drops to 70, turns off and then goes back on once temp rises back to 74. the narrower the range, the more sensitive. you don't want it too sensitive, otherwise system is constantly cycling from ac to heat. I know of no car system that allows you to set the sensitivity (and very few home systems). Fairly common, though for commercial HVAC systems.
Note: Temp sensitivity feature is only available in North America. They've disabled it in other markets.
#30
Temp sensitivity seems like a good idea. Although in practical I haven't changed the setting in the 6 months I've had the car, so in that sense I guess it has been useless to me.
#31
#32
I'll take a pic tonight...but I've actually never used it (left it on the default medium) so I have no idea if it actually works as intended.
#34
Hey Guys,
First thanks for the help when I was scoping out used f-types.
Now that I have a well cared for 2014 F-type S with about 48k miles, I'm dealing with a central vent issue where it gets stuck on half way up half way, or stuck half way on the way down. This happens a large enough percent of time that I plan to take it to dealer. Anyone have comments on what it costs to fix at a dealer.
The car is a dream otherwise.
All the best,
Christopher
All the best,
Christopher
#35
#36
I encountered this issue as well. Sticking halfway up or down intermittently. Fortunately it was fixed under warranty. Looking at my invoice it looks like they replaced that vent assembly, part # T2R17443PAJ and "reprogrammed the module". List price on that part appears to be about 300 but your dealer may mark it up more. Assuming you got the part from the dealership and had them do it my best guesstimate would be 450-600 dollars. I'm basing that on guessing it's 1-2 hours of labor but I don't have any record of what they'd actually bill out for labor on the replacement. You could save a little sourcing the part yourself I would imagine.
Mbourne (01-15-2019)
#38
#40
This is the cheapest I have been able to find the replacement part $307 plus shipping
https://parts.harperjaguar.com/oem-p...ver-t2r1450pvj
