Air Vent stopped raising.
Old 01-21-2019, 02:13 PM
sov211's Avatar
Received 2,283 Likes on 1,380 Posts
[QUOTE=JIMLIGHTA;2013475]Since the thread has resurfaced and I had no idea the menu existed either, here is a US photo
This is not temperature sensitivity! It has nothing to do with the temperature settings...note the icon to the left: this adjustment controls the recirculating air function and the sensitivity refers to the point of air contamination (for lack of a better term) at which the outside air vent is closed off and the system is put into recirculating mode.
  #42
Old 01-21-2019, 02:52 PM
Unhingd's Avatar
Received 4,664 Likes on 3,369 Posts
Originally Posted by MarshallL
This is the cheapest I have been able to find the replacement part $307 plus shipping
https://parts.harperjaguar.com/oem-p...ver-t2r1450pvj
That's just the cover. I don't believe that includes the mechanism that needs to be replaced.
  #43
Old 01-22-2019, 12:00 PM
JIMLIGHTA's Avatar
Banned
If it stopped working anyway, can it be intentionnally jammed in the open position?
  #44
Old 01-22-2019, 01:23 PM
MarshallL's Avatar
Please let us know what part needs to be replaced.
  #45
Old 01-22-2019, 08:26 PM
Unhingd's Avatar
It has to be one of these parts:
https://parts.jaguarreno.com/v-2016-...ter-components
  #46
Old 01-27-2019, 04:14 PM
Default Pricing
I ended up having the service done at the dealer in Baton Rouge on 10/2/18.
They updated the computer system, but that did not do the trick in my case.
Ended up replacing: 1x t2r17443paj vent fica for $398.41
Labor was another $145
Diagnosis was another $145
Thanks for all the upfront info when I started this tread.
Mbourne (01-29-2019)
  #47
Old 04-15-2019, 08:05 AM
AnD3rew's Avatar
Originally Posted by DJS
That was typical on the 2014. Mine raised fine, but I'd have to push it to go back down. There was a TSB for that, and my dealer fixed it the first time it was in for service. Works perfectly now. No idea what you'd have to pay for that, too bad it wasn't fixed under warranty.
does anyone have a copy of the TSB? Might really help as I have to take mine to the dealer to be fixed and may be able to have them help me out even though warranty has expired if it is a known issue with a TSB.
  #48
Old 04-15-2019, 09:13 AM
DJS's Avatar
DJS
DJS is online now
Received 2,141 Likes on 1,431 Posts
I will try to remember to check my service records. PM me after a couple of days, in the likely event that I forget.
AnD3rew (04-17-2019)
  #49
Old 04-15-2019, 10:42 AM
MarshallL's Avatar
Can anyone provide a PDF from TOPIX on how to replace this part?
  #50
Old 04-18-2019, 06:01 PM
DJS's Avatar
DJS
DJS is online now
Here’s what was done to my car to fix it. They reference Bulletin K243...
AnD3rew (04-18-2019)
  #51
Old 04-18-2019, 06:03 PM
DJS's Avatar
DJS
DJS is online now
The following 2 users liked this post by DJS:
AnD3rew (04-18-2019), Ldasampaio (02-01-2022)
  #52
Old 04-18-2019, 06:22 PM
agreenlee's Avatar
My center vent on my 2014 F-Type V8S failed out of warranty. The dealer charged $306 for the part. Labor brought it up to $615. I believe that they re-engineered this part as it was a known problem. Replacement part is working perfectly.
  #53
Old 04-18-2019, 07:47 PM
AnD3rew's Avatar
Thanks so much DJS, this is perfect and my VIN is in range too, this will help a great deal when I go to put pressure on the dealer for an out of warranty warranty repair.
  #54
Old 12-23-2019, 07:28 AM
Itsadoozy's Avatar
I have same issue on out of warranty car. Did you get anywhere with this announcement and repair?
  #55
Old 02-01-2022, 04:15 PM
Ldasampaio's Avatar
Default Same issue here...
I have the same issue here....how can I know if my F-Type can be repaired under this Technical Bulletin? Its out of warranty btw...
  #56
Old 02-01-2022, 04:35 PM
DJS's Avatar
DJS
DJS is online now
If it's out of warranty, you'd have to pay for it.
  #57
Old 02-01-2022, 04:45 PM
Borbor's Avatar
Pretty sure I read there's a DIY fix/repair for this if you are out of warranty.
  #58
Old 02-01-2022, 04:49 PM
Ldasampaio's Avatar
Me too! Cant find it now 😅
  #59
Old 02-01-2022, 06:40 PM
62jeff's Avatar
Can’t find the thread but I reposted their attachment in a response to another’s issue a few years ago
https://www.jaguarforums.com/forum/f...3/#post2242472
The following 3 users liked this post by 62jeff:
Borbor (02-01-2022), Ilyushin79 (02-02-2022), mvining (02-09-2024)
  #60
Old 02-01-2022, 07:20 PM
Borbor's Avatar
well done Jeff , Kudos to the original author on a excellent guide and PDF
Quick Reply: Air Vent stopped raising.
