Airbag light is on
Airbag light is on
Hello!
I have an F-type 2016 which is imported from USA. When I bought it, the airbag light in the cluster did not light, but after a while it has started to light up. Not always but almost. At the rearview mirror in the roof it also says "passenger airbag off"
When I searched for instructions online to turn the airbag off/on, you can do it under Vehicle setting in the instrument cluster. But I don't have that choice and I can't find anywhere that it should be possible to disconnect it.
Some tips or ideas?
Have a good day!
Magnus
Some tips or ideas?
Have a good day!
Magnus
Received 3,259 Likes
The only way I know to remove the warning light and get the SRS working again is to fix the sensor error then delete the error code, and the only way to remove an SRS error code is with the factory SDD tool.
Depending on where he is the OP may find that an SRS/airbag light on means an automatic fail of any roadworthy check, never mind that the SRS is completely disabled.
