Alignment adjustment points
Hi all,
I believe camber, caster, and toe is adjustable in the front and only toe in the rear; is this correct?
Also where are the adjustments points for camber and caster in the front, and camber in the rear? Does anyone happen to have any pics?
Lastly what are the jag recommended specs for the R and SVR?
You are correct: camber, caster, and toe is adjustable in the front and only toe in the rear. Knowing where the adjustment points are, is of no use unless you have an alignment machine in the garage. If you do, I'll pm you the alignment instructions.
Mpowerr (11-15-2016)
Mpowerr (11-16-2016)
phd12volt
08-07-2009 11:24 AM
