Aluminum Cooling Pipes - Finally!!
#321
Thanks! I'm dropping my car off on Monday to do both valve covers, and the Y pipe and upper Pipe from Euro Amp will be going in at the same time.
I'll be doing the oil cooler as well and associated seals, as well as all injector seal kits. I'm at 90k miles, my injectors seem to be fine, not sure if it's worth the extra cost to replace all 8 injectors too. Seems like if one breaks I guess I'll have no choice.
Shop would not install the URO brand stub cooling part into the water pump, I think based on their reputation as a parts supplier. I trust the shop, so I'll skip that one too.
#322
#323
Picked up our '14 yesterday, after installation of the EuroAMP V6 V.2 kit, the complete one with metal rear pipe and water pump.
ISSUES: wrong variation of thermostat housing in the kit (exchanged by EuroAMP, Christian is GREAT).
Then, one of their small metal fittings didn't snap in as firmly as the old one did according to our mechanic, so we replaced with a new JLR piece. Mechanic said that OE fitting doesn't break or leak in his experience...
Also, one of the kit's rubber coolant hoses wasn't shaped properly, and restricted flow when kinked to fit, so rather than wait we had him put in a JLR one.
We are set, for a couple years...
PS: Our tech is an experienced long-time Jaguar guy. He hand-writes the service description/bill in CURSIVE. LOL
#324
#325
I bought a pair of the metal coolant pipes and they are installed in my 2013 XF 3.0 SC. The fit seems good. There is a small gap where the two metal pipes join together, but I believe the o-ring is seated far enough into the lower pipe to create a good seal. I am currently pressure testing the cooling system. No evidence of leaks so far.
Mike
Mike
#326
#328
Our mechanic stated that he HAS seen metal pipes leak after a period of time (even with his 'European-sourced' parts). Because of that, he inspected the EuroAMP set, BEFORE he agreed to do the replacement job.
He said that the fit of our was good! Will monitor over time.
PS: It was below freezing in our garage today...
#329
About 15,000 miles before it started to leak intermittently and a further 10,000 miles since it began to leak daily (this one does nearly 40,000 per year). If I squeeze the upper radiator hose, I can force coolant out. I've o-rings that've done more than 100,000 miles, unless it's something else, I reckon it's the o-ring which's failed, the pipes were quite snug and required the screws to get them to fit together. The Y so far's not leaking at the bases.
#330
If the fit was tight, is it possible you pinched the o-ring on install annd damaged it?
#331
#332
Took it apart this afternoon. Pipe slide right off as the o-ring had hardened and failed. Replaced with a proper one and re-assembled everything. No more leaking, at least not after 30 minutes of driving. Now I'm worried the other 2 on the Y will meet a similar fate..........
#333
Good to hear you fixed it.
One problem I have had is Jaguar seems to use odd sized O-rings? In my AC system I could not match them up at all and had to order 2 very expensive Jaguar branded O-rings.
Were you able to use after market replacement O-rings? Any idea of the size?
I like the idea of using better O-rings but do we want Viton, Silicone, Nitrile or?
#334
#335
I was talking to my independent mechanic about the aluminum Y pipes a few months ago when I had my 2014 F V8S in for it's annual service. He told me that he has done quite a few installs of aluminum Y-pipes and has also seen quite a few of them fail after a while from O-ring leaks. His theory is that the aluminum heats and cools the O-rings faster than the plastic pipes do and ages the O-rings to failure. He said he actually prefers to install the new plastic Y-pipes and has not seen one fail but has had to repair leaking O-rings on the aluminum Y-pipes.
On my car, it is very low miles and his advise even though I have the old style Y-pipes is to just keep a close eye on them for now. Then possibly install the full Euroamp Kit in the future especially if they come out with the rear crossover pipe, or maybe just but in the stock new plastic Y-pipes if people keep on having O-ring leaks.
If you know what sizes of O Rings you want. You can shop for what ever kind of O-Ring you want at McMaster Carr https://www.mcmaster.com/products/o-rings/
Good luck
Wayne B.
Good luck
Wayne B.
#336
Good luck
Wayne B.
Good luck
Wayne B.
The following 2 users liked this post by jahummer:
cbarr (01-23-2024),
Supersprint Sport Exhausts (01-22-2024)
#337
Thanks,
John
#338
Yeah, my only concern with installing the EuroAmp kit was the seals themselves. I did some cursory searches before contacting them, and they stated they currently use OEM replacements. Which is of course what I'd expect them to say - so time will tell how long mine last installed in my XJ.
