Am I able to use a trickle charger during COVID?
Hello. I have a 2015 Jaguar F-Type convertible (3.0L 6cyl). From being held in captivity by COVID, my baby had been sitting in the driveway for a few months. Long story short, I ended up having to get a new battery. I have a 6v/12v trickle charger that I've used without issue for years on a Subaru kept in storage part of the year. With no end of the pandemic in sight, I'd like to use the same trickle charger on the Jag and avoid the dead batter problem again. Because I want to be able to drive the car randomly, I'd prefer to simply pop on and off the jaw clips rather than do some type of wired connection. The Jag manual is basically useless for this, it doesn't even show where the batteries are located. I know where the one in the trunk is located and that it help supports the ECO Feature. However, it was the other (front?) battery that was replaced. Any guidance or advice would be greatly appreciated. The stuff I read on the forums did not apply and scared me. Thanks!
DC
Thank you. If there is only one battery, then this will be the second one I've bought in two years. Yikes. I am aware of the jump connection under the hood, but there is only a connector for the positive (red). There is no connector for the negative (black). I could ground the negative-black to a metal bolt, but I don't know if that will work. If there is only one battery (mechanic at the dealer said there were two, was he talking about somethingelse?), are there any issues connecting directly to it with the trickle charger?
Also, some of the older models have a second battery for the ECO Start/Stop feature.
DC
Arski:
It seems that you do not use your F-Type often enough (or far enough). The electronic modules in this car need full battery voltage all the time - when the battery voltage drops all sorts of (apparent) problems appear. The best thing you can do, the thing that will eliminate any battery issues, is to fit a battery maintainer, not a trickle charger. The most favoured battery maintainer is the CTEK brand and the easiest thing to do is to fit the connector cord PERMANENTLY to the battery system in the trunk - and both your batteries are there, the main battery to the left, the stop/start battery to the right (there are threads here on how to do it - so easy). You then simply connect the CTEK charger to the cord. Done. It takes 3 seconds if you are slow to connect and disconnect - and your next battery purchase will be 6 or 7 years from now.
The photo below shows my CTEK unit on the wall and the cord connecting to the small connector at the trunk lid.
I wound up hardwiring a standard charger pigtail in the trunk of my FType per instructions that I found online at an F-Type forum.. Was not difficult. Then just popping the trunk & connecting whenever I wasn't driving the car for extended periods.
Worked great.
Was told that connecting to the jumper ports will NOT keep the entire car charged & that the connection to the specified connection points in the trunk underneath the carpet was the best - & it did work great for me Used a Battery Tender Junior which was plenty if the battery was already charged when starting.
Good luck!
Worked great.
Good luck!
OP, if you have a 2015 F type, you do have a second smaller auxiliary battery to support the electronics while the engine is shut down during a drive. Whereas the primary battery is locate towards the left rear of the boot, the auxiliary battery is located right front of the boot in front of the subfloor cubby.
schuss (02-15-2021)
