Am I shifting correctly?
Some of the most fun I have in my Ftype is shifting gears up via the paddles on an automatic car.
I get these sweet burps when I'm pushing down hard on the gas, the RPM's are in the 3-4K+ range and then I shift up. All while I'm pushing down on the gas. You get this sweet satisfying sound.
I've noticed however that whenever I do this, I'm able to smell something burning. I think its my clutch though I'm not totally sure.
What do you guys think? Am I shifting correctly? I don't want to burn the clutch prematurely, but is there any other harm I'm causing by shifting this way?
Is there anybody else who does something like this regularly?
Received 3,225 Likes
See this post on another forum: XFRS to F-Type R Coupe full exhaust conversion.
It appears that the F-Type engineers deliberately designed a "controlled misfire" into the car to give the exhaust it's distinctive crackle and pop, and I suspect you are smelling unburnt fuel from this.
Temperatures are cooler this time of year and the smell does not dissipate as quickly as in warmer weather.
Desert Hiker
usually happens on upshifts.
Also this last road trip, there were times when I wan't shifting manually at all. Car was in auto and the smell would just come through the cabin.
Its ok by me, but my passengers usually think someone has farted. (not a very premium feeling![Wink](https://www.jaguarforums.com/forum/images/smilies/wink.gif)
I would just mention the problem to them and explain the circumstances when it occurs. I don't care if car is spitting skunks from the tailpipes, you should never smell anything inside a sealed cabin (particularly at speed). Fuel leaks and exhaust leaks will, however, enter the cabin.
f_in_seattle (12-27-2015)
So I still get this fumes smell in my car from time to time and today I saw the post for the K410 campaign which sounds like it could be a solution for these fumes that I'm smelling.
https://www.jaguarforums.com/forum/f...e-done-172240/
I've scheduled an appointment for next week to apply K410 to my car. Will let you guys know if that fixes this issue for me.
