Another what is this thing? Help
First person I asked was the sales guy. He had no idea. It's a hard plastic cover that matches the trim inside the trunk. Idk
Received 3,259 Likes
Thanks. Can you take a pic of this thing installed? I looked all over the place and have no idea where this goes. The cargo cover in my car doesnt rest on pins. It rests on a lip. Then again, I'm not sure what the cargo cover is. I'm referring to the removable cover that hides the tire repair stuff. The luggage cover that opens with the hatch also doesnt rest on pins that I can see.
Open the hatch and look under the front corners of the cover (front as in towards the front of the car) and you will see the slots that the pins of the cover sit in, and on the undersides of those slots you will see the offending pieces. Well in your case you should see only one of them and a gap where the other should go!
