Anti-freeze smell after driving
Didn't find anything with a search, I smell this in my garage as soon as I pull in and park. Never see a drip on the floor and can't find an obvious leak. I've never added any but the car has been to the dealer several times and I don't know if they have.
Anyone experiencing this??
I noticed an occasional antifreeze smell through the vents in my car several months ago. I kept looking for leaks but found nothing. Last month, I got a low coolant warning on the dash. I noticed the coolant tank was right at the minimum mark. I added water and took it to the dealer. The water pump had developed a small leak and was replaced. No problem since.
I would suggest having your dealer check out the water pump.
Just left my F-type with the dealer to investigate the coolant smell. They said they pressure tested the system and tested for the presence of coolant in the exhaust, and found nothing amiss.... Warranty expires next month and it's a 100 mile round trip to the dealer. I've owned cars/motorcycles for 55+ years and I know if you smell coolant with the engine hot it's because something is leaking. At least it's on record as a problem.
Update: No issues or coolant smell with my car since the water pump was replaced.
A tip for anyone having coolant work done on their car: The coolant is pushed into the engine via vacuum. I drove my car home from the dealership without any issue after the new water pump was installed. The next day, I parked in my garage after a drive and the engine sounded like a pot of water was boiling on top of the supercharger. This concerned me and I took some video to show the dealer. They told me that it is possible air got trapped when adding the coolant after the water pump installation. The drive to the dealer must have solved the problem because no noise could be detected, even with a stethoscope, and no problem since.
A very slow leak and it was not easy to see ... make sure you keep a copy of the work order for future.
Lawrence
Agree. The characteristic sweet smell of coolant is unmistakeable. Smell it and there's leakage somewhere--whether by design (overflow venting) or more commonly a failure or imminent failure (hose, water pump, radiator, etc.) of some sort. Good you made it a matter of record.
