Antilaser priority laser jammer head placement
Happened upon a motor patrol sitting in plain sight in the middle emergency lane, radar in hand, pointing at both of us to pull over to the right. Having been in this position before, I immediately began to slow and pull to the right - while the other driver kept on booking - I of course was hoping the CHP would naturally take up pursuit of the fleeing vehicle. Not on this day...
After the obligatory exchange of license and registration, the officer proceeds to ask if I have a laser jammer? "No I don't sir" He peers around the interior, takes a walk around the vehicle, comes back to my window and asks again: You sure you don't have a laser jammer? "No sir, what seems to be the problem?"
Hands me my license and registration back and proceeds to explain [paraphrased]: I spotted you well in the distance travelling at an elevated speed. I'm using the most advanced Laser speed detection approved in Calif. (Lidar something or other) capable of consistently accurate readings at 4000 ft. I targeted your vehicle 3 or 4 times and got no reading. Targeted the other car and got an immediate reading at 84. Targeted you again and finally got a reading of 80 at about 400 ft. Are you sure you're not using a jammer?
Proceeds to ask a few general questions about my car (specs, engine size, HP), takes another walk around the vehicle, this time more admiring than inspecting, comes back to the window again and states: That is one damn beautiful automobile, how do you like it? We proceed to have a 5-10 minute conversation about the car, the Jaguar engineered "theater", etc., and I'm idling in dynamic the whole time cause I forgot to turn off the engine... so he asks me to rev it a few times to crank up the exhaust note. I oblige, he grins, then gives me the "please check your speed sir; have a nice day" send off.
Aside from the fact he was curious about not getting a hit on my car at some distance, it became quite clear the dude was far more interested in checking out my car, up-close and personal like. LMAO!
It occurred to me later that without a front license plate, there is very little flat and perpendicular/reflective surface on the front of the F-Type to bounce a laser signal off of...
The following 5 users liked this post by IronMike:
2002xtypejamo2956 (05-03-2022),
amcdonal86 (12-28-2015),
ferrral (09-24-2020),
Greggbhill (12-28-2015),
Lookout! (01-02-2016)
On every other car I'm aware of cops are able to get a reading by targeting the headlights. No front plate needed. It's entirely possible that the cop IronMike encountered may have simply been incompetent.
I'd suggest we not get overconfident. I will be having AL Priority jammers installed.
I think 2 ALP head units need to be installed in the grill. I'm thinking of fitting a pair of them in the non-functional vents on either side of the grill. I'm not ready to remove the front clip to fit this just yet (I'll also install a remote radar head and the GPS antenna many of the units need).
Unfortunately for me NJ has a front license plate requirement so I'm using the Big Mike "Sto n sho" solution Big Mike's Performance Parts STO N SHO for Jaguar
I'd order radar absorbing paint if JLR offered it as an option.
Oh interesting, I didnt know the outermost vents were non functional. They might be too far apart for a full coverage install though. You will need a center head as well.
I was given a warning as the "nice" officer probably only wanted to get a closer look at the car. Why else would he pull me over for an 81 in a 75....
I remember a big debate on the Corvette Forum when the C6 came out about a decade ago that was almost a duplicate of this thread discussion. The same "theory" was advanced that they were also "stealth cars" and could only be "lasered" if a front plate was on the car.
That one was also definitively debunked after a short period of time.
![Icon Lol](https://www.jaguarforums.com/forum/images/smilies/icon_lol.gif)
Of course the learned result was a huge let-down...
Based on their Receiver Head Sensitivity Testing performed in January 2015, the ALPriority Laser Jammer consistently demonstrated the widest sensitivity range of all jammer devices tested. Measured from the center of the receiver head toward the outside the vehicle, the ALP provided an astonishing 84" wide swatch of sensitivity to Lidar detection.
This would suggest that if you installed a pair of ALP heads side-by-side, directly on the centerline of the vehicle, two ALPriority heads would then provide a 14ft wide (84" left and 84" right) path of detection to a Lidar signal. This of course is much wider than any passenger vehicle. Now conventional wisdom suggests that receiver heads be spread apart by a few feet, widening the overall detection range even further.
Assuming this to be true, mounting the heads in the side vents rather than the center grille, may well create a void in the coverage between the two heads because they are too far apart. A third head would indeed solve this problem as you suggest, though with the detection range of the ALPriority heads in particular, this would seem to be completely unnecessary if one simply mounted the heads toward the outer edge of the center grille.
Important that readers understand this applies to the ALPriority laser jammer system only. The next best performer of the systems tested was 45" of coverage by the Laser Interceptor product. Two LI heads would combine to provide 7 to 8 feet of detection sensitivity, which just barely covers the width of the F-Type, with little margin for error.
There are a number of different products in the marketplace claiming to do the same thing... I happened across this one: Veil G5 Stealth Coatings
Relatively inexpensive extra measure of protection (in addition to radar and/or laser detection hardware) to provide precious seconds of extra time to react and lower your speed.
I haven't tried this yet, and not sure I would be applying to any painted body surface, but since police seem to focus on headlights and/or license plates first, I am strongly considering ordering some and applying to my headlights exclusively. Since I don't run a front license plate, not applicable for me there. Besides, I also have Xpel film on my headlight lenses, so if the stealth coating itself yellows or fails in some other way, removing and replacing the Xpel film on just the headlights would be a relatively minor additional cost to the full radar/laser protection equation.
f_in_seattle (01-03-2016)
I'm so happy with my MY15 S-coupe but I might trade her in if InControl App hooked up with "accessories" like this giving us WAZE and countermeasures control right on the head screen. Mechanics of the car are superb - wouldn't change anything, but software and the desire to see a BRG with Camel coupe in my garage could interest me in a trade.
I used Sygic on a 450 mile drive yesterday. MAJOR FAIL...it doesn't refresh, locked up at two critical turns causing me to miss them, and seems to be a major data user. I've heard nothing but great things about Waze, but I can't use a mapping app that is on my iPhone...too small and low for me to see.
