Any benefits with gasoline higher than 93 octane
Hi guys, I have a question, would our cars benefit from gasoline rated higher than 93 octane or would be a not worth the additional cost. Sunoco use to have 94 octane. There are some fuel sellers who have 100 octane fuel, which is expensive. Your thoughts please.
Received 2,263 Likes
I hope it's not the placaebo effect; I went from running a tankful of standard pump 95 RON (UK) to 99 RON and have been running it on the more expensive fuel exclusively.
The only noticeable difference that I felt, was on acceleration. It felt more responsive.
Apart form that I didn't notice anything. I know some claim better MPG, but fuel economy isn't exactly top of the list with a car like this anyway.
It deserves the best you can put in it.
I though it was an 8 point spread for Euro fuels. No? I thought the Euro owner's manual required 95RON, having based their HP claims on that fuel.
Could well be depending on the typical blend components coming from the local refineries. I am not familiar with the blending practices in the EU. In the U.S., the spread will be in the 10-12 point range. That spread is particularly high when using oxygenated blend components (ethanol, ethers) like we do here in the States.
HMmm. I'm confused now.
Having always been told and believed that N. Am fuel had an 8 point RON-MON spread which means that our 91AKI is equal to 95RON. All modern Jags have a recommendation to run on 95RON, having being were certified on this fuel.
If you are correct that our fuels have a 10-12 point spread, then Jag is saying that 89AKI is adequate. (??)
