Any experience with RaceChip?
#61
So if RaceChip is over-boosting the engine by fooling the ECU, what is happening with the the built-in safe-guards in the ECU? Are they also being fooled? Would/could this not lead to potentially catastrophic engine damage?
Does anyone know just how much additional boost is designed into each RaceChip map level?
#62
Not quite. Properly tuned engines are still monitoring actual parameters to ensure that conditions remain within tolerable limits. The RaceChip, however, is modifying sensor inputs to fool the ECU into a modified behavior. No assurance that safe parameters are being maintained.
#63
Wanted to just post my experience with the RaceChip -- just installed it over the weekend. I purchased the RS model with the app functionality.
First the good news -- it was *really* easy to install. Took me about 30 min -- and I had no issues at all following their instructions.
The not so good news - I've been using/experimenting with the different race modes (mode 4, 5, and 6) that are pre-loaded into the device. I definitely notice a bit more power in the higher gears but the low end torque seems to me to be nearly the same as stock. I've emailed them to see if there's any additional tuning they can do to modify what I'm experiencing but at this point I'm not impressed enough to keep it -- I'm seriously considering taking advantage of their 30 day return policy. It just doesn't seem worth it for the "power" gains (or lack thereof) I've seen thus far.
#64
Please keep the forum informed. Thanks
#65
I'm a bit concerned about some of the comments in this thread about pushing/deceiving the car too much so I'll see what they say about modifications they can make remotely. I was ok with the pre-programmed modes since these were tested. But, if they send me modifications I wouldn't want them to push the limits too far (in the hopes of satisfying my need for lower end torque) and in turn cause damage.
It seems as if the other users of the Racechip in this thread were using it on the xkr -- not the F-type. So I'll be sure to tread carefully.
fujicoupe (09-23-2019)
#66
The SVR runs the same amount of boost as an FType R. We tested both files.
__________________
Stuart Dickinson
Managing Director
VelocityAP Industries Ltd.
O: (1)250-485-5126
E: Stuart@VelocityAP.com
www.velocityap.com
![](https://www.jaguarforums.com/forum/signaturepics/sigpic147732_1.gif)
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
#67
![](https://cimg2.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1024x476/jaguar_v8_s_supercharger_pulley_f176ce55abe7c416eb32c3c706e9f945aaa5de65.png)
Here are two runs with the pulley and Racehip on Map 7 plotted on top of the pulley baseline.
![](https://cimg1.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1024x507/jaguar_v8_s_racechip_supercharger_pulley_3cd9c604533a7a6f522643f7df181c4cbe6d8b21.png)
#68
So after much consideration and a little research, I will stay away from this RaceChip product and all other "piggyback" type of ECU products.
I googled "RaceChip blown engine" and came across quite a few threads on different manufacturer car forums.
I can't say what percentage of customers have had issues, but even if it is as low as 2-3%, it is not worth the trouble to me.
Interestingly, RaceChip seems to have been around for many years. However it does not seem too common as used on Jaguars.
I also found the following article (which is more than 15 years old), to be quite interesting...
https://www.nytimes.com/2004/02/13/t...new-chips.html
I will still follow this thread to see and evaluate the results that other Jaguar owners have with this product.
#72
I assume the same as the difference between the XKR and XKR-S, some fuel adjustments and raised torque limiters.
This is what the SVR press release says:
Changes to the engine’s calibration – adopted from the F-TYPE Project 7 – deliver power and torque ratings of 575HP and 516-lb.ft. of torque.
Enlarged air intakes in the front bumper, together with revised charge air coolers and redesigned hood vents, deliver corresponding improvements in cooling system performance and powertrain efficiency.
A new lightweight Inconel titanium exhaust system has been fitted as standard which withstands higher peak temperatures, reduces backpressure and eliminates 35-lbs (16kg) of mass from the vehicle.
To make the most of the increased engine output, the eight-speed ZF® Quickshift transmission has been recalibrated to reduce shift times and increase torque availability during launch.
#73
Torque demand, is the simple answer. In practise there's a lot more tables than that to modify, but it's just not requesting all the available power. To get from 575 to 600 we do have to raise boost, but that can be done with the bypass valve settings, there's enough mechanical boost to get 600BHP before you have to change hardware.
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
#74
#75
#76
#77
Thanks for the response. Your initial statement gave me pause because I just started looking at these for my 2016 XF AWD and I'd hate to limit Winter traction (I live at altitude in Colorado). If I can just turn off the RC that's not a huge concern I guess.
I'd like to get a little more of the performance back that has been software limited on the 340hp 35t. Has anyone had good results with that particular engine + Racechip? Would I get closer to the 380-400hp these engines were designed to produce?
I'm still under warranty for another 2.5 years or I'd be looking at a VAP tune and some sort of aftermarket intake and exhaust.
George05 (10-01-2019)
#78
Overall (and please feel free to say "I told you so") I've concluded that the only / right way to improve the performance is to get the Velocity ECU tune plus the pulley. While the chip seemed like a good way to get the improved performance without the warranty risk, it really isn't enough of an improvement to be noticeable. The other part of this that was a bit annoying was the fact that I would have to 'turn on' the chip every time I started the car.
For those still curious about the RaceChip -- I gotta say their customer service is A+++ so if you decide to give it a shot, you do have their 30 day return policy to rely on.
#79
Thanks for the write up. When you say you have to turn it on every time you start the car...does it lose the last setting each time it is powered down? It looks like some of the RC models you just set it with a screwdriver and forget it. Would you recommend that instead of the ones that require a phone app?
#80
