Anyone experience problems with there A/C?
I have experienced a weird problem with the A/C compressor only working sometimes and it's hard to replicate the problem. Sometimes when I turn on the climate control it will blow humid air and the A/C will not get cold. Just blow in neutral temp air and fog all the windows. If I turn off the car and turn it back on it will usually start functioning normally. Does anyone have any clue what this is?
Another weird problem, not associated with the one above, is the car windows will roll down randomly. I approached the passenger side opened the door and both Windows rolled down. The two LEDs on the driver side door were blinking as the windows rolled down. It happened 4 times. One time I returned to the car with the windows all the way down and it was luckily only lightly drizzling. I hypothesize its the smart top unit. I'll have to remove it to confirm.
In response to the last post:
I was just about to post with an issue I am having. If I set the temp at say, 72 F, and it is 55 F out, the ventilation works fine for the first 1/2 hour or so. Then it starts cycling hot hot hot for a couple minutes, then cold cold cold for a couple minutes. It might average out to 72, but it sure is annoying when it happens.
I don't use auto because I don't want the AC on all the time. Is there a way to decouple them? I don't want the extra wear of the compressor or the lowered MPG from it being on all the time.
Thoughts?
Thanks!
Thoughts?
Thanks!
My A/C was in manual mode. I usually keep it in manual. When I switched it to auto it didn't help. My eco mode was off, not sure how that's related? I tried all the temperature settings when it occurred but nothing worked, besides pulling over on the highway and turning on and off the car. It just seems like the compressor decided to take a nap. It happened again while driving on the hwy and I discovered I can turn off the car while coating abs restart it like an old fashioned keyed car. That worked to get everything back to normal.
The compressor won't burn out and the impact to MPG will be negligible - and anyway we drive big engined sports cars, I am pretty sure MPG wasn't a primary driver for you getting an F Type
JagAlb (05-19-2017)
However, your other comments lead me to believe that you actually have a fault somewhere. Next time it happens, try pressing the auto button and turning the dials to "LO". Whip out the infrared thermometer and use your iphone to video tape the vent temperature and showing the LO dials. Use this evidence when bringing to the dealer and explain that it is intermittent.
That's my recommendation, but it likely requires you to pull over (which will also let you restart the car and fix the compressor) to capture the video as I think you'll need both hands to film and use the thermometer.
Zmoothg - I'm pretty sure there has been a TSB relating to low AC output if memory serves me well.
I think there was an issue with a temperature controlled switch in the AC system.
Try asking if your dealer can shed any light using: JTB00380 which relates to the Pressure sensing valve.
Regarding the windows - Remove the battery terminal (+'ve or -'ve) and leave the car and have a brew for ten minutes.
Reconnect the battery terminal and run the Window Reset procedure that has been posted on the forums many times (or find it in the owners manual), thst should cure it.
Dealer had to replace the entire AC compressor, which is a shared part with the F-Type, if I recall correctly. So no, you don't have to live it. It's a problem.
zmoothg (05-08-2017)
So I had the A/C compressor replaced and the car is still doing the same thing. When I get on the car hard for a couple miles the A/C compressor will decide to stop doing its job. The only solution is to turn my car off and on, and then it works for awhile longer, but will eventually stop working again. Jaguar is still investigating and they are completely confused as to the issue, they believe it might be a software or sensor problem. Has anyone experienced anything like this?
