Anyone know where factory horn located?
I found an air horn that I liked and all it says I have to do is find the factory horn and move the two wires from factory horn to the replacement air horn. I was wondering if anyone has put in an air horn and if it was similar in installation. If anyone knows where the horn location is. Thank you in advance
The horns are just behind the front grille. The best picture I could find is attached, and it is easily accessed from above by opening the hood and removing the front plastic cover. C1RH02A is the horn connector, and the harness side connector part number is XR850178 (may help you to find the mating side so you can plug in?). Pin 1 (black) is ground, pin 2 (grey with brown stripe) is connected to battery voltage via a 15A fuse and relay in the engine junction box.
Smoke Em (04-30-2016)
Horn location
Harry Dredge
05-01-2016 07:23 PM
Jnb6755
04-29-2016 07:28 PM
