Is anyone running a full bolt on V6?
I know with tune and crank pulley, the V6 is sitting about 445 to 450 hp, but does anyone have intake, high flow cats, larger intercooler, etc? Is there any other bolt ons that will get the V6 to 500 hp?
I have a pair of cylinder heads and am going to talk to a local machine/ performance shop about porting/ polishing the heads and custom cams, valves, springs. I know I will need a new tune to bring it all together (maybe switch to Viezu), but I am checking to see what all of this is going to cost me and I'll let you know if it seems worth it ( keeping it under $6k), or not and just trade and go to a V8 F-Type.
If anyone has already done anything I am considering, I'd love to hear about it!
Thanks in advance,
Danny
Thanks in advance,
Danny
If you are going to port and polish heads, you should also port and polish and gasket match supercharger. I am not aware/convinced that it would be cost-effective upgrading any of head's hardware due to lack of aftermarket parts, if you go that way post your findings and research here.
If you are going to tune and pulley, make sure you upgrade cooling. Current setup is up to thermal limit on stock setup.
In this thread a guy ported his supercharger, and added nitrous and methanol injection but it was a V8.
https://www.jaguarforums.com/forum/f...itrous-164223/
Terrance39 just posted a parts list for his methanol injection set up
https://www.jaguarforums.com/forum/f...-parts-220896/
Panthro (05-10-2024)
The following 4 users liked this post by Unhingd:
SinF (07-26-2019)
So, a larger inter cooler to go with heads and supercharger porting?
From what I can tell right now, cams and valve train will have to be custom. That’s what machine shop is telling me. I am also going to go ahead and get upper pulley at this point, I think. Maybe after porting, cams and valve train, it will be worth it.
This is prohibitively expensive to do right and just not worth the risk of doing on a budget. Leave existing hardware in place and focus on low-hanging fruit. That would be port and polish, port matching, pulleys, tune, exhaust with high flow cats, improved cooling.
Incorrect. V6 and V8 use different blowers, there is also one in-between.
Well, I wonder how we can find out which one is "in between," and if it is compatible with the V6. hmmm
Yes, the supercharger will be ported also, just forgot to mention. Can the current head's hardware take more power? The performance shop mentioned going to a 1mm different exhaust valve to start.
I have a sit down scheduled with performance shop this week and I have also reached out to Crane Cams and another company on how much it will be to custom make "higher" performance cams for the V6. I'm sure they will tell me if this is feasible, or not. It's not like they can't develop a better cam based on the current specs. I'm sure that it's more that no one has asked them to, so they feel there is no market for it, but what the heck do I know --> total beginner.
I already have tune and pulley. No one, including Velicity AP has suggested for me to upgrade cooling with the current tune and crank pulley. AND, they themselves have also told me that larger intercooler, nor high flow cats will increase the power of the car.
This is why I'm trying to get you guys to brainstorm with me here. 450 hp can't be this power plants limit. Maybe if Crane Cams, or another company can develop a nice cam for our V6 cars, we can get a group going? lol
Viezu has a crank pulley that is 15%.... I wonder how much better it is? Will it create that much more power? Anyone looked into it?
Received 3,226 Likes
With the bigger crank pulley and VAP tune it is putting out 450 hp or 150 hp per litre, which these days is the benchmark for hi-po street engines.
We need to remember this engine is based on the AJ133 which was designed in 2008, so getting 150 hp per litre out of it is pretty damn good.
And by all reports the AJ133 SC was designed to put out 750 hp max so again 150 hp per litre.
Adding all this up it seems obvious to me that 450 hp is the max we can (safely) expect to get out of the V6 without radical and expensive mods.
The following 2 users liked this post by OzXFR:
Paul_59 (07-27-2019),
sparky fuze (07-27-2019)
Unless Crane can build variable lift cams, cam replacement might be problematic. I suspect the F-Type cams already incorporate both street and performance profiles.
If you haven't fitted high flow / low restriction cats then this would usually lead to a small potential increase in power on most supercharged or turbocharged engines.
This approach will often need an appropriate tune to deal with potential check engine light (CEL) conditions it may cause.
The aim is to remove restriction to airflow in intake and exhaust, more airflow with appropriate fuelling and ignition timing leads to more power.
To paraphrase what others have stated the sky is the limit with power increase potential, but not for under 6K on an engine that doesn't have a significant aftermarket bolt on turning market.
Custom mods equals big budget.
V6 (AJ126) and V8 (AJ133) engines are very closely related, the supercharged engines have variable valve timing (VVT) on both exhaust and inlet, the aim being to optimise valve timing for different rpm and load conditions to maximize power at low, mid and high revs and load.
The NA (naturally aspirated) versions of these engines have camshaft profile switching (CPS)(variable cam lift) based on rpm and load in addition to variable valve timing.
Presumably there's a reason the supercharged engines didn't have CPS, my guess would be the gains were less than could be achieved with SC.
It's also possible to gain performance without huge power increases by for example significant weight reduction and better tyres.
^^^This. Forged wheels + Michelin 4S, Wortec two piece brake rotors, lithium battery. I think somebody said this would shave about 100lb to 150lb off the car.
Unknownsir (08-03-2021)
That's very much accurate ;-) Engine, transmission etc. brings it close to $58K. The Supercharger alone is $5K
It's a 3.4L. on the Vengeance 640 No problems on the street, it behaves rather well and has no reliability issues.
3.7L is the crate engine version that is bored out to match the V8
The following 3 users liked this post by FType17:
It was designed specifically to replace the AJ133 NA which I believe was discontinued a few years ago.
The aftermarket intake and high flow cats will be part of the performance upgrades, but as I was told by VAP, they do not give more power, so I am focusing on what will. I have an extra pair of heads, so I will drop them off tomorrow at the shop and we will see what can be done besides port/ polishing & the modification to the exhaust valves.
No one has commented on the Viezu 15% pulley and what difference that can make. Would 3% be worth anything? 20hp?
