Anyone Using Run Flats?
I had huge Michelin runflats on a 2007 Z06 I owned. Can't believe the Jag performance spec is any more demanding than that.
It will be interesting to learn if there is a run-flat that will work on the F. I was told by Jaguar dealers (2) and a MB dealer relative to an AMG model that there was no adequately rated run flat performance tires made. Now, I had a friend throw away the run-flats he had on a Lexus because they were so squirrelly in the cold. How did the ones on your Corvette work out. Handling ok? Ride ok? The F has a pretty stiff ride even with normal side wall tires.
I never tracked the Corvette when I owned it. Having said that, I had no issues with the run flats for normal spirited street driving. The reason why I brought up the topic is that I like to road trip with the Jag as I know many of you do as well. The longest ride I've taken so far is about 800 miles. Just like to have a little back up that's better that a can of flat fix when I go on a road trip.
Run flats are so hard they bend rims and belch air regularly. Terrible choice unless its a slow speed car or minivan.
I had run flats on my 2008 Audi TT, wear on the tires was about 30%, picked up a nail. You can't patch a run-flat and in a AWD car you can't just replace one tire. Run flat tires aren't cheap. That damn nail cost me something like $3,200. Never again... (Tires weren't that great either). Sadly the tires were the only thing I didn't like about that car (no that's now true, I had the 6 and wanted more power...).
Go on a road trip with run flats and have a problem with one in the middle of nowhere in the middle of the night and see how you like run flats. Fat 20 performance tires are hard enough to find under those circumstances (unless you have a Jag GM with you with a spare f-type and speed dial to a 24/7 tow company!).
Regarding your comment that they're not for performance cars, both Bridgestone and Dunlop Sport Max run flats have been fitted to GT-R as oem fitment for years.
totalimmortal363
01-08-2012 02:05 PM
mattysta
08-28-2010 08:54 PM
