Audio System - At my wits end
Old 02-10-2022, 04:58 PM
Borbor's Avatar
Are you sure it is your door speakers and not the shitty rear subs that may have blown and muddying everything?
Old 02-10-2022, 05:01 PM
dwilk's Avatar
it’s hard to tell… would that make the vocals sound terrible too? For example, the vocals in “Heavy” by Flight Facilities sound so compressed or something that it makes the speakers sound blown (which they aren’t, they are new speakers)
Old 02-10-2022, 05:49 PM
Borbor's Avatar
i guess trouble shooting would be fading the system all the way forward and turndown the subwoofer/bass level to quite low to eliminate the rear as much as possible (or disconnect rear speakers completely but alot more work) to see if any difference.
Then fading to left and then to right side to isolate each speaker set inturn.
if it is indeed an amp problem then none of this will help where as if it does then a speaker issue.
ps : had the meridian system in an Evoque previously and base system was absolutely fantastic but had twice as many speakers and 10x better than the F type
Old 02-10-2022, 05:50 PM
dwilk's Avatar
thanks, I’ll give that a try when I get it back from the dealer
Old 02-10-2022, 10:04 PM
dennis black's Avatar
your speakers have individual crossovers ,you should get a DSP amp run the speaker wire directly to each speaker, not through the plug network ,how you would do it 20 years ago ,so the amp will give each speaker its correct frequency,
night and day difference
Old 02-11-2022, 10:28 AM
Jag Bass's Avatar
Originally Posted by dwilk
They are the same impedance so I can't imagine it being an issue. I have seen others do the speaker upgrade without the upgraded amp
If you are speaking of the Meridian Signature speaker the door woofers are 4 ohm where the base and the surround are 2 ohm.
Old 02-11-2022, 10:29 AM
dwilk's Avatar
wow, ok this is news to me. I can swap the door woofers back.
is it possible this caused some sort of other damage?
  #28
Old 02-11-2022, 10:35 AM
Jag Bass's Avatar
https://www.youtube.com/watch?v=aFQIudNRrcs
https://www.youtube.com/watch?v=DXPGhVMQPyc
F-type DSP and crossover is all done electronically within the amplifier. Other than a protection capacitor on each tweeter there are no passsive crossovers in these system. Each speaker is wired directly to each channel from the amplifier.
Old 02-11-2022, 10:44 AM
Jag Bass's Avatar
I noticed the output dropped after I installed the door woofer which is to be expected since the amplifier power will be cut in half for the Meridian Signature door woofers. The are a better woofer as there was an improvement in cone control. You will definitely want to be sending more power to these woofers than the base or surround amp can supplying them. My system is powered by Audiocontrol D-6.1200 for the front stage and a Audiocontrol 1.300 for a 10" Sub in a custom boot well enclosure. Definitely get rid of the woofers behind the seats, they are garbage but keep the rear fills behind the head rests or you will loose your backup warning tones.
  #30
Old 02-11-2022, 10:47 AM
dwilk's Avatar
I believe lower impedance than designed for = overheating (possible damage?) and higher = lower output/quieter. even after adding dynamat my doors still rattle pretty bad with bass (I've turned it down and turned the rear subs up to compensate), so increasing the bass in the doors isn't feasible until I can get the rattle dealt with.
  #31
Old 02-11-2022, 10:53 AM
Jag Bass's Avatar
Yes, while the doors are not the best scenario as an enclosure if the rattles are tamed they will produce some very good sub bass. Best solution for sub bass is a rear enclosure. I pull my sub channel signal for my 1.300 sub amp from the door speaker channels, much better than what you can get from the subs behind the seats.
  #32
Old 02-11-2022, 10:55 AM
dwilk's Avatar
interesting, does decreasing the bass through the audio settings effect that?
Still, bass doesn’t appear to be my issue, as the vocals that sound heavily compressed occupy either the tweeters or midrange unless something is seriously wrong with my DSP sending the signal to the wrong speakers
  #33
Old 02-11-2022, 10:57 AM
Jag Bass's Avatar
The factory base meridian and meridian surround amps are designed to drive 2 ohm door woofers, should not have caused damage putting in the Meridian Signature door woofer which will actually cause the amp to make less power being a 4ohm driver.
  #34
Old 02-11-2022, 10:59 AM
Robtrt8's Avatar
That “Heavy” track is not very clean. Seems like a ton of T-Pain style Autotune distortion.
Try this track:
Super clean production. Makes almost any system sound good.
  #35
Old 02-11-2022, 11:00 AM
Jag Bass's Avatar
Are you still all factory with exception of replacing the speakers with the Meridian Signature speakers in the doors, or have you added aftermarket amp with high level input from the factory amplifier?
  #36
Old 02-11-2022, 02:14 PM
dwilk's Avatar
Try this track: https://youtu.be/9YhipiMNiYk
it does have some distortion, but it sounds a million times better on every other system I've listened compared to the f-type. it was just one I picked where it sounds super bad.
  #37
Old 02-11-2022, 02:43 PM
Robtrt8's Avatar
I enjoyed discovering the track from your post, it’s on my playlist now.
  #38
Old 02-11-2022, 02:44 PM
dwilk's Avatar
lol, it’s catchy, never used to be into music like that until listening to the Sirius/XM chill station
  #39
Old 02-14-2022, 08:57 AM
Robtrt8's Avatar
Finally got a chance to listen to that track on my Type’s custom system after listening to it all week in my Pace’s 880watt Meridian. OMG, does it hit.
Just wondering what the shop who changed out your drivers thought of your system and if they had any suggestions?
  #40
Old 02-14-2022, 01:03 PM
FtypeATX's Avatar
I did the recommended speaker upgrade a few months ago, along with sound deadening on the door sheet metal. After doing one door completely I used my phone to fade back and forth instantly between the left and right channel, so I could A/B the change, and the difference between the two was really minimal to my ears. It sounded slightly better, but for the $500 I spent on the new speakers I wouldn't recommend it. The sound deadening is probably worth it though.
The biggest improvement I got was fading everything to the front in the EQ, so it would stop trying to play vocals and stuff from the crappy speakers behind the seats. That was actually a pretty significant improvement. I still need to do some felt tape in the back panels to cut down on all the rattling there though.
eeeeek (02-14-2022)
Quick Reply: Audio System - At my wits end
