Audio System - At my wits end
it’s hard to tell… would that make the vocals sound terrible too? For example, the vocals in “Heavy” by Flight Facilities sound so compressed or something that it makes the speakers sound blown (which they aren’t, they are new speakers)
i guess trouble shooting would be fading the system all the way forward and turndown the subwoofer/bass level to quite low to eliminate the rear as much as possible (or disconnect rear speakers completely but alot more work) to see if any difference.
Then fading to left and then to right side to isolate each speaker set inturn.
if it is indeed an amp problem then none of this will help where as if it does then a speaker issue.
ps : had the meridian system in an Evoque previously and base system was absolutely fantastic but had twice as many speakers and 10x better than the F type
your speakers have individual crossovers ,you should get a DSP amp run the speaker wire directly to each speaker, not through the plug network ,how you would do it 20 years ago ,so the amp will give each speaker its correct frequency,
night and day difference
https://www.youtube.com/watch?v=aFQIudNRrcs
https://www.youtube.com/watch?v=DXPGhVMQPyc
I noticed the output dropped after I installed the door woofer which is to be expected since the amplifier power will be cut in half for the Meridian Signature door woofers. The are a better woofer as there was an improvement in cone control. You will definitely want to be sending more power to these woofers than the base or surround amp can supplying them. My system is powered by Audiocontrol D-6.1200 for the front stage and a Audiocontrol 1.300 for a 10" Sub in a custom boot well enclosure. Definitely get rid of the woofers behind the seats, they are garbage but keep the rear fills behind the head rests or you will loose your backup warning tones.
#30
#31
I believe lower impedance than designed for = overheating (possible damage?) and higher = lower output/quieter. even after adding dynamat my doors still rattle pretty bad with bass (I've turned it down and turned the rear subs up to compensate), so increasing the bass in the doors isn't feasible until I can get the rattle dealt with.
#32
Yes, while the doors are not the best scenario as an enclosure if the rattles are tamed they will produce some very good sub bass. Best solution for sub bass is a rear enclosure. I pull my sub channel signal for my 1.300 sub amp from the door speaker channels, much better than what you can get from the subs behind the seats.
Still, bass doesn’t appear to be my issue, as the vocals that sound heavily compressed occupy either the tweeters or midrange unless something is seriously wrong with my DSP sending the signal to the wrong speakers
#33
#34
#35
interesting, does decreasing the bass through the audio settings effect that?
#36
That “Heavy” track is not very clean. Seems like a ton of T-Pain style Autotune distortion.
Try this track: https://youtu.be/9YhipiMNiYk
Super clean production. Makes almost any system sound good.
#37
#38
#39
#40
I did the recommended speaker upgrade a few months ago, along with sound deadening on the door sheet metal. After doing one door completely I used my phone to fade back and forth instantly between the left and right channel, so I could A/B the change, and the difference between the two was really minimal to my ears. It sounded slightly better, but for the $500 I spent on the new speakers I wouldn't recommend it. The sound deadening is probably worth it though.
The biggest improvement I got was fading everything to the front in the EQ, so it would stop trying to play vocals and stuff from the crappy speakers behind the seats. That was actually a pretty significant improvement. I still need to do some felt tape in the back panels to cut down on all the rattling there though.
eeeeek (02-14-2022)
