Automatic Rear Hatch Squeaking
Received 3,259 Likes
I reckon you need to narrow it done a fair bit.
When exactly does it squeak - on the way down, on the way up, both, at the start, at the finish, all the way through etc?
What type of squeak - low pitched or high pitched, constant pitch or variable pitch etc?
One side or both sides?
And, most importantly, exactly where from - you should be able to listen closely to the squeak from the outside as you raise and lower the hatch and be able to narrow it down to exactly which part or component is squeaking.
Then, depending on what you find, some lubricating spray or oil (eg WD 40, lithium grease etc) or plastic/rubber lube (eg Gummi Pfledge - spelling!) could do the trick.
Worst case scenario - one or both struts are knackered and need replacing = big $.
If that doesn't work then I can see three more spots to try some lube/spray - the two ends of the strut where it rotates on pins, and the hatch hinge right up by the roof.
On my car all three of these spots are a bit dirty (and I'm a bit OCD about keeping my car clean) and I don't get snow/sleet/mud etc which on your car could build up even more muck in these places.
Lasts much longer and doesn't attract dust and dirt.
Yep, that'll do the trick.
Same stuff as PTFE in effect, see here: https://www.nes-ips.com/teflon-vs-ptfe/
CRS 123 (12-11-2019)
sadepol01
02-11-2016 08:22 PM
