AWD Linked Dyno
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
Previously I have had a hard time to smoothly dyno my old XFR on RWD Superflo dyno and it took many true to get a clean run of my baseline and after Tune and pulley.
Now I have a new 2017 XE-R Sport V6 AWD and want to know how you guys are doing your AWD F-Type dynos cleanly without interventions kicking in?
In my Dynamic menu I have a window that shows what drive wheels are being applied based on throttle input and NOT wheel spin. Seems to be in a percentage of AWD anytime you are on the gas and only RWD when cruising or lightly on the gas.
So what steps have you or would you donor get proper readings on a AWD linked dyno? I am assuming NOT to pull any fuses and just turn DSC all the way off by holding the DSC button for ten seconds and leave it in S mode?
Since I have the same trans I guess I should use 4th or 5th gear for the true 1:1 ratio? Any tips to prevent up shifts near redline? My XFR always would short shift on its own but not sure about the XE yet. Also not depressing the passing gear switch at the WOT was a help also back then.
My car only has 1k miles on it so far so I'm not sure if it's going to give me all of it yet. But it's worth a try as my tune is on the way.
Lastly how are you getting RPM pick up if. It getting it from the OBDII port as the coil pack is hard to get the clamp onto and not move?
MaximA (11-29-2016)
