back speakers -- almost no output!
So, finally, after a late spring, I'm tooling around with my F-Type, getting all the dust off the car after long winter/spring storage, checking capacities and levels, and tweaking the settings.... including the audio, which was probably prompted by my new XE daily driver.
Anyhow, as I played with the balance and fader, I realized that I have almost no output from the rear speakers. What output that is there is distorted.
So, the question: Bad amp, blown speakers, or have i something set wrong? I doubt if it's the latter, so wondering if amp or speaker failure is typical.
thx for the help!
thx for the help!
thx for the help!
thx for the help!
thx for the help!
thx for the help!
The interior had to be taken apart because BOTH rear sub-woofers were blown, and insulate the door speakers and rear. Configured audio amp using IDS/SDD for the software update. Both doors and parcel shelf- verified fixed. Insulator sound kit T2R21163x4 Parts T2R10501 2- T2R21202 2-T2R21163 2-T2R21164
Supposedly , it took a some time for the software update to configure. Because I have the extended warranty until 2020, no charge with exceptional service.
And for ADELE- and Earth/Wind/and Fire, Chicago, Santana, she sounds great !
RGPV6S (04-30-2018)
I only have JTB00432v2...
https://www.dropbox.com/s/fx74fn2exc...ystem.pdf?dl=0
This fixed everything. I FURNISHED EVRYTHING THEY DID AND PRINTED OUT INCLUDING THE BULLETIN.
pjr, I'm not sure I would be satisfied with whomever you spoke with and would try again with the manager.
I had this fixed in APRIL ! And as Unhingd said, it needed the software update.
The bulletin was correct ( JTB00432v4 )
xe92
General Tech Help
11-15-2019 11:00 PM
