Base vs S
hello everyone! just registered on here after browsing through this forum for some time now..
I'm currently in the market for a car and the F-Type has my fancy - well, I have been eyeing it for some time now and given the prices of used ones, its all the more enticing.. I'm looking at 2015-16 coupes - base and S models (no R for me).
Theres two things about this car that entices me - the looks and the sound! Looks wise both the base and the S are similar enough to me except for the badges and brake pads, so not a big deal. When it comes to the sound - is there a difference between F-Type base with Active Exhaust vs the S?
I went through this forum on related discussions and I dont think I care too much for LSD or the extra 40hp, if I get the same sound experience with the Active Exhaust option in the base, then that would satisfy my criteria.
This will be a weekend car at best, no tracking, nothing crazy - just a fun car. So any thoughts on base vs S?
- SB
- SB
dwmilton (12-17-2020)
- SB
- SB
Active exhaust has the valves that can/will be opened by the ECU to make the exhaust louder.
It has varied over the years as to whether or not the base car came with active exhaust or not, so there are base cars that do not have active exhaust and base cars that do. I believe all S cars have always had active exhaust.
The other option is 'switchable' active exhaust, which is the addition of a manual switch by the shifter (between the seats) - active exhausts may optionally have the manual switch, which you may want. Looking at car pics online, you should look for the switch (it has 2 exhaust pipes engraved on it) by the shifter - that will tell you the car has switchable active exhaust.
Active exhaust and switchable active exhaust should be the same on the base and S models when fitted.
If you just want a cool f-type and not super concerned about the extra 40hp, adjustable suspension, slightly larger front brakes etc, I reckon the base is a great option, and you could always tune it to over 400hp with a VAP tune relatively inexpensively compared to the price of the 'S' if you ever wanted to...
The base model does not have the Limited Slip Differential (LSD), nor the configurable Dynamic options. The base can be tuned to over 400hp however for $750 or so, without the LSD and the 380mm brakes to go with it, it's not going to make it anywhere as good as the S in performance driving.
From a power prospective, you can very easily get around 420HP simply with an ECU Flash.. We offer that for $735.00 and includes your own handheld device
As pointed out above, unless you have the upgraded brakes, (red calipers or black calipers with the 380mm option), you will probably have good but not excellent braking capacity. The exhaust question has been answered extensively above.
It probably wont matter for a weekender, but the ride in the base is a lot harder than the ride in the S, unless the dynamic mode is engaged in the S which makes the ride harder than the base.
The ride does soften over time when the seats become more giving, but personally I would go to the S for that reason - or buy a base with 5,000 miles on it where the seat would have softened up because someone else's **** has taken the punishment.
You can always restore the stock tune.
We represent a tuner that provides insurance against any damage resulting from the tune, and by law, the Magnuson-Moss Warranty Act requires the manufacturer to honor their warranty unless they can prove that the damage was caused directly by the tune.
Any reputable tuner stays well within the acceptable safety margins.
The burden of proving that the tune is the sole cause of the failure is on the manufacturer and not the consumer. That's why they hardly ever decline a repair based on a proper tuning job. But yes, the remapping stores an OBDII code P137F if I recall it correctly. No matter what tuner does it.
Both V6 variants end up with 420hp. The V6 base goes from 340 to 420 and the V6S 380hp turns into 420. The gain on the base model is 80hp and very noticeable.
- SB
- SB
This tune has been installed by well over 100 forum members, is fully customize-able to your preferences and includes a number of options such as pops & crackles, eco stop/start off etc.
__________________
Stuart Dickinson
Managing Director
VelocityAP Industries Ltd.
O: (1)250-485-5126
E: Stuart@VelocityAP.com
www.velocityap.com
![](https://www.jaguarforums.com/forum/signaturepics/sigpic147732_1.gif)
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
If you bench flash the computer with KTag, CMD Boot Mode, or Dimsport Trasdata it will not store the code.
Similarly the CMDFlash OBDII 'Shop' tool (we have a handful which we loan out) does not store the code, because it doesn't actually read the ECU. It isn't the flashing that stores the code it's actually the 'read.' Since the CMD does a virtual read and downloads a matching file from a server, it never trips the code. That's also the reason that it can tune the Flexray cars (2017-on RR and 2018-on Jaguar) that use Bosch MED17.8.32 where the Powergate 3 cannot.
Although, that might change, we have had a open request with Alientech for nearly 1 year to get them to develop the Flexray protocols for Jaguar. We just finished testing the 2.0L MED17.9 for them so that one is done. 17.8.32 that's used in the FType may be longer. But once we have tested that one, it will become available for you to use through Viezu.
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
What it actually stated at the time, as was explained to me by them (although it may be different now) is that in order for the insurance policy to pay out, it requires an independent investigation to conclude that the tune was the cause of the engine failure.
So it's not a blanket coverage.
You're 100% correct about the manufacturer warranty and detect-ability as well. Notwithstanding bench flashing or using CMD, but even then the flash counter will not match what SDD says at the dealership.
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
BruceTheQuail (01-30-2018)
The following 2 users liked this post by NigelW:
BruceTheQuail (01-30-2018),
dwmilton (05-03-2020)
